To start automating your Facebook posts to Pinterest, first access Pabbly Connect. Open your browser and enter the URL publy.com/connect to reach the Pabbly Connect workflow page.
On this page, you will see options to sign in or sign up for free. If you are a new user, click on the sign-up option to create an account. Pabbly Connect currently offers a free trial, allowing you to explore its features without any cost.
2. Setting Up Facebook as Your Trigger Application
In this section, we will set up Facebook as the trigger application in Pabbly Connect. After signing in, select Facebook Pages as your trigger application. This will initiate the workflow whenever a new post is created on your Facebook page.
- Choose the app event as “New Post”.
- Click on “Connect with Facebook Pages” to build the connection.
- Select your Facebook account and allow access.
Once connected, select the specific Facebook page where you will be posting. This setup ensures that any new posts made on this page will trigger the automation in Pabbly Connect.
3. Creating the Pinterest Action to Post Pins
Next, we will configure Pinterest as the action application in Pabbly Connect. After successfully setting up Facebook, search for Pinterest in the action application section. Select it to proceed with creating a new pin whenever a Facebook post is made.
- Choose the app event as “Create Pin”.
- Connect your Pinterest account by clicking “Connect with Pinterest”.
- Select the Pinterest board where you want the new pin to be added.
This connection allows Pabbly Connect to automatically fetch the image and caption from your Facebook post and create a corresponding pin on your Pinterest board.
4. Mapping Data from Facebook to Pinterest
In this step, we will map the data from Facebook to Pinterest using Pabbly Connect. This is crucial for ensuring that the right image and caption are transferred to your Pinterest board. During the setup, you will be prompted to enter the image URL and title for the pin.
Instead of manually entering these details, use the mapping feature in Pabbly Connect. Press the slash symbol to access the previous application data, and select the image URL and caption from the Facebook post.
This dynamic mapping eliminates the need for repetitive data entry, making your automation seamless and efficient. After mapping, click on “Save and Send Test Request” to verify that the integration works successfully.
5. Verifying the Integration Between Facebook and Pinterest
Finally, it’s essential to verify that the integration between Facebook and Pinterest is functioning correctly through Pabbly Connect. After completing the previous steps, check your Pinterest board to see if the new pin has been created successfully from your Facebook post.
Refresh your Pinterest board, and you should see the image and caption from your Facebook post displayed as a new pin. This confirms that Pabbly Connect has successfully automated the process of posting from Facebook to Pinterest.
This integration not only saves time but also enhances your social media presence by automatically sharing your content across platforms. With Pabbly Connect, you can easily manage multiple social media integrations without any coding skills.
In this tutorial, we demonstrated how to use Pabbly Connect to automate the integration between Facebook and Pinterest. By following the steps outlined, you can streamline your social media management and save time on manual postings.
