To start automating notifications from Google Blogger to Discord, you need to access Pabbly Connect. Open your browser and search for pav.com/connect to reach the homepage of Pabbly Connect.
If you are a new user, click on “Sign up for free” to get 100 free tasks every month. Existing users can simply sign in. After logging in, find the option to access Pabbly Connect by clicking on “Access Now” to reach the dashboard.
In Pabbly Connect, you can create a new workflow to set up your integration. Click on “Create from Scratch” to start a fresh workflow. You will be prompted to describe your automation; input “When a new post is added in Google Blogger, send a message on Discord”.
Next, Pabbly Connect will ask for the Google Blogger trigger. Select “New Post Added” as your trigger. For the Discord action, choose “Send Channel Message”. Review your workflow and click “Approve and Create” to finalize the setup.
3. Setting Up the Trigger for Google Blogger
Now, let’s set up the trigger in Pabbly Connect. After selecting the app and event, click on “Sign in with Google” to connect your Google Blogger account. Choose your desired account and grant access to Pabbly Connect.
Once connected, select your blog ID from the dropdown menu and specify the status as “Live” to capture only live posts. Click on “Save and Send Test Request” to confirm the setup. This will pull the latest blog post from your Google Blogger account.
4. Integrating Discord with Pabbly Connect
With the trigger set, the next step involves integrating Discord. Click on “Connect with Discord” in Pabbly Connect. Allow access as prompted, ensuring that your Discord account is logged in on the same browser.
To set up the webhook, navigate to your Discord channel settings. Create a new webhook named “New Blog Update”. Copy the webhook URL and paste it into Pabbly Connect. Extract the webhook ID and token from the URL for use in your automation.
- Create a new webhook in Discord settings.
- Name it “New Blog Update”.
- Copy the webhook URL and paste it into Pabbly Connect.
After entering the webhook ID and token, proceed to add your message text. Use data mapping to dynamically insert the post title and URL into your message.
5. Testing the Automation Setup
After configuring the message text, click on “Save and Send Test Request” to test your setup. You should receive a successful response indicating that the message has been sent to your Discord channel.
Check your Discord channel to confirm that the new blog post notification appears correctly. With this, you have successfully automated the process of sharing new blog posts from Google Blogger to Discord using Pabbly Connect.
In this tutorial, we demonstrated how to automate notifications from Google Blogger to Discord using Pabbly Connect. By following these steps, you can streamline your blogging process and keep your community informed effortlessly.
