1. Accessing Pabbly Connect for Lead Management
To start categorizing leads as hot, warm, or cold, you first need to access Pabbly Connect. Go to the Pabbly website and sign up for an account if you are a new user, or log in if you already have an account.
Once logged in, navigate to the dashboard, where you can create a new workflow. This is where you will set up the automation to connect your lead sources with Zo CRM through Pabbly Connect.
2. Setting Up the Workflow in Pabbly Connect
In this section, you will create a workflow that triggers when a new lead is generated from Facebook. Use the quick workflow builder in Pabbly Connect to set up this automation.
- Click on “Create Workflow”.
- Enter a name for your workflow, such as “Connect Facebook Leads to Zo CRM”.
- Choose “Facebook Lead Ads” as the trigger app and select “New Lead” as the trigger event.
After setting the trigger, connect your Facebook account to Pabbly Connect. You will need to authorize the connection, allowing Pabbly Connect to access your Facebook leads.
3. Configuring Zo CRM Integration
Next, you will set up the action in Zo CRM where the leads will be sent. Choose “Zo CRM” as the action app and select “Create Lead” as the action event. This is crucial for categorizing your leads based on their status.
Map the fields from your Facebook lead to the respective fields in Zo CRM. Ensure that you include:
- Lead Name
- Email Address
- Contact Number
Once the fields are mapped, you can set conditions to categorize leads as hot, warm, or cold based on their responses in the lead form. This is where Pabbly Connect plays a vital role in automating the process.
4. Categorizing Leads Using Pabbly Connect
Now that your workflow is set up, it’s time to categorize the leads based on their urgency. Create filters in Pabbly Connect to determine if a lead is hot, warm, or cold.
For example, if a lead indicates they want to purchase within three months, they should be categorized as a hot lead. Use the router feature in Pabbly Connect to create multiple paths based on these conditions:
- If the purchase time is within 3 months, tag as Hot Lead.
- If the purchase time is within 6 months, tag as Warm Lead.
- If the lead is just exploring, tag as Cold Lead.
By implementing these filters, Pabbly Connect ensures that your sales team can prioritize leads effectively, improving conversion rates.
5. Testing the Integration
After setting up the workflow and categorization, it’s essential to test the integration. Submit a test lead through your Facebook lead ad and monitor how it flows into Zo CRM.
Check if the lead is categorized correctly based on your conditions. If everything works as expected, you will see the lead appear in Zo CRM with the correct status. This testing phase is crucial to ensure Pabbly Connect is functioning correctly.
Make sure to refresh your Zo CRM account after submitting the test lead to see the updates. This will confirm that Pabbly Connect is successfully integrating your leads and categorizing them as intended.
In this tutorial, we explored how to automatically separate hot, warm, and cold leads using Pabbly Connect with Zo CRM and Facebook integration. By utilizing Pabbly Connect, you can streamline your lead management process, ensuring timely follow-ups and improved customer conversion.
