To start using Pabbly Connect for integrating WhatsApp with Facebook Lead Ads, first navigate to the Pabbly Connect website. Here, you can either sign in or sign up for a free account. New users can explore the software with 100 free tasks monthly.
Once signed in, you will see the dashboard where you can select Pabbly Connect. This is where you will create a workflow to automate sending WhatsApp messages to your leads.
In this section, you will create a workflow in Pabbly Connect to automate WhatsApp messaging. Click on “Create from Scratch” to build your workflow. You will be prompted to describe your automation.
  • Select “New Lead” as the trigger from Facebook Lead Ads.
  • Choose “Send Text Message” for the action using Pabbly Chatflow.
  • Approve and create the workflow after reviewing the preview.
This setup allows Pabbly Connect to listen for new leads from your Facebook ads and automatically send a WhatsApp message to engage with them immediately.
3. Setting Up the Trigger for Facebook Lead Ads
Now, you need to configure the trigger for your workflow in Pabbly Connect. Click on “Connect with Facebook Lead Ads” and select your Facebook account. Grant the necessary permissions for Pabbly Connect to access your data.
Next, select the page and lead form you want to use. For example, if your page is named “Digital Dynamics,” choose it from the dropdown. This ensures that only leads from this specific form are captured by Pabbly Connect.
4. Sending WhatsApp Messages via Pabbly Chatflow
After setting up the trigger, you will configure the action to send a WhatsApp message. In this step, you will connect to Pabbly Chatflow to send personalized messages to your leads.
  • Access your Pabbly Chatflow account to retrieve your API token.
  • Map the lead’s phone number from the trigger response to the WhatsApp message field.
  • Compose your message, using dynamic mapping to personalize it.
Once you have configured the message, click on “Save and Send Test Request”. This will send a test message to ensure everything is working correctly through Pabbly Connect.
5. Testing the Integration and Finalizing Setup
Finally, it’s time to test your integration. Make a test submission using the Facebook lead ad testing tool. This will generate a lead that Pabbly Connect will capture and process.
Check your WhatsApp to confirm that the message was received successfully. If everything is set up correctly, you will see the personalized message sent to your lead. This confirms that Pabbly Connect is functioning as intended and automating your workflow efficiently.
In this tutorial, we explored how to use Pabbly Connect to automate WhatsApp messaging for leads generated through Facebook Lead Ads. By following the steps outlined, you can streamline your communication and improve lead engagement.
