To start integrating WhatsApp with Pabbly Connect, you first need to access the Pabbly website. Simply search for Pabbly Connect in your browser and navigate to the homepage. Here, you will find options to sign in or sign up for a free account.
If you are a new user, click on “Sign Up Free” to create your account. This grants you access to 300 tasks every month for exploring the software. If you’re an existing user, just click on “Sign In” to enter your dashboard.
Once you are logged into Pabbly Connect, you will need to create a new workflow. Click on the “Access Now” button to enter the Pabbly Connect dashboard. From here, you can start building your integration workflow.
To create a workflow, follow these steps:
- Click on “Create Workflow”.
- Choose to create from scratch or use AI.
- Select “New Leads” from Magic Bricks as your trigger.
After setting this up, you can proceed to the next steps of your integration process using Pabbly Connect to send WhatsApp messages automatically.
