To start automating WhatsApp messages for new HubSpot CRM contacts, you first need to access Pabbly Connect. Visit the Pabbly Connect website at www.pabbly.com/connect and sign up for a free account. This allows you to test the integration with 100 free tasks every month.
Once logged in, you can explore the features of Pabbly Connect. This platform enables you to seamlessly connect HubSpot CRM with WhatsApp Cloud API, allowing for automated messaging without any coding skills. Here’s how to get started:
  • Visit the Pabbly Connect website.
  • Sign up for a free account.
  • Log in to access the dashboard.
With your account ready, you can now proceed to set up the integration workflow.
The next step involves setting up the trigger for your automation. In Pabbly Connect, select the trigger event as “New Contact Created” in HubSpot CRM. This means that every time a new contact is added, the automation will be triggered.
To connect HubSpot CRM, click on the “Add New Connection” button. You will be prompted to log into your HubSpot account and grant necessary permissions. Once connected, click on “Save and Send Test Request” to ensure the connection is established correctly.
  • Select “HubSpot CRM” as the trigger application.
  • Choose “New Contact Created” as the event.
  • Log in to HubSpot and authorize Pabbly Connect.
This setup ensures that every new contact in HubSpot will trigger an automated WhatsApp message, streamlining your communication process.
3. Sending WhatsApp Messages via Pabbly Connect
After setting up the trigger, the next step is to configure the action to send messages via WhatsApp. In Pabbly Connect, select WhatsApp Cloud API as the action application. You will need to add a new connection by providing the necessary API credentials.
Enter the required details such as your WhatsApp Business Account ID, phone number ID, and token. These credentials are essential for Pabbly Connect to authenticate and send messages through WhatsApp. Once you’ve entered the information, click on the “Save” button to establish the connection.
  • Select “WhatsApp Cloud API” as the action application.
  • Provide your WhatsApp Business Account ID and token.
  • Click “Save” to connect.
This allows Pabbly Connect to send messages directly to your new contacts on WhatsApp, enhancing your customer engagement.
4. Mapping Data for Personalized Messages
To ensure that the WhatsApp messages are personalized, you need to map the data from the HubSpot trigger to the WhatsApp message fields. In Pabbly Connect, select the phone number and name fields from the HubSpot response to dynamically insert this information into your WhatsApp messages.
For example, you can craft a message like “Hi, {name}. Welcome to our service!”. By mapping the name field, each new contact will receive a personalized greeting as soon as they are added to HubSpot. After setting up the message, click on “Save and Send Test Request” to test the automation.
  • Map the phone number and name fields from HubSpot.
  • Craft a personalized message for new contacts.
  • Test the automation to ensure messages are sent correctly.
This personalization increases the effectiveness of your communication, making new contacts feel valued and welcomed.
5. Conclusion
In this tutorial, we discussed how to automate WhatsApp messages for new contacts created in HubSpot CRM using Pabbly Connect. By following the steps outlined, you can set up an effective communication workflow that enhances customer engagement.
With Pabbly Connect, integrating HubSpot CRM with WhatsApp has never been easier. This automation not only saves time but also helps convert leads into paying customers efficiently.
Start using Pabbly Connect today to streamline your business processes and improve customer interactions.
