To begin integrating your website form with Go High Level using Pabbly Connect, first, access the Pabbly website by typing pabbly.com in your browser. From the homepage, you can sign in or sign up for a free account, which provides you with some monthly tasks to explore the platform.
Once logged in, navigate to the Pabbly Connect application from the dashboard. Here, you can create workflows to automate your processes efficiently. If you are a new user, consider utilizing the free tasks to familiarize yourself with the features before upgrading.
After accessing Pabbly Connect, click on the “Create Workflow” button to start building your automation. Name your workflow something descriptive, such as “Automatically Send Website Leads to Go High Level.” Select a folder for organization, like “Forms Automation,” and click on create.
  • Click on “Create Workflow” to initiate your automation.
  • Name your workflow for easy identification.
  • Select an appropriate folder for better organization.
Upon creation, a box will appear where you need to define your trigger application. This trigger is essential as it starts the automation process whenever a new form submission occurs.
In the trigger application, select “Webhook by Pabbly” and choose the event “Catch Webhook.” Click on connect to generate a unique webhook URL. This URL acts as a bridge between your website form and Pabbly Connect.
Next, access the code for your website form in a text editor. Replace the existing webhook URL with the one generated by Pabbly Connect. Save the changes to ensure that the form can send submissions to the webhook.
  • Select “Webhook by Pabbly” as your trigger application.
  • Choose the “Catch Webhook” event to start capturing submissions.
  • Insert the generated webhook URL into your website form code.
After saving the changes, go back to Pabbly Connect and test the webhook by submitting your form. This step is crucial for capturing the response and ensuring everything is set up correctly.
4. Adding Action Steps in Pabbly Connect
Once the webhook response is captured, it’s time to add an action step. Click on “Add New Action Step” and search for “Lead Connector V2”. Select the action event “Create Contact” to add new leads to your Go High Level account.
When prompted, connect your Go High Level account to Pabbly Connect. You can choose to add a new connection or select an existing one. After connecting, you’ll need to map the fields from the webhook response to the corresponding fields in Go High Level.
  • Click “Add New Action Step” to initiate the process of adding leads.
  • Select “Lead Connector V2” as the action application.
  • Map the fields from the webhook response to Go High Level fields.
This mapping ensures that every time a new form submission occurs, the lead data is accurately transferred to Go High Level without manual entry.
After setting up the action step, it’s essential to test the integration. Click on “Save and Send Test Request” to verify that a new contact is created in Go High Level. Refresh your contacts page in Go High Level to see if the new lead appears correctly.
If the test is successful, you’ll see a confirmation response from Pabbly Connect. This indicates that the integration is functioning as expected. If you encounter any issues, review the steps to ensure everything is correctly set up.
  • Click “Save and Send Test Request” to initiate the test.
  • Check your Go High Level contacts page for the new lead.
  • Confirm the details are correct and reflect the submission.
This testing phase is critical to ensure that your workflow is operational and that leads are being captured correctly through Pabbly Connect.
In this tutorial, we explored how to use Pabbly Connect to integrate your website form with Go High Level for automated lead management. By following the steps outlined, you can ensure that every new form submission is captured and processed efficiently.
Utilizing Pabbly Connect not only streamlines your workflow but also enhances your lead management process, allowing you to focus on growing your business.
