1. Automating Webinar Reminders with Pabbly Connect
To automate webinar reminders, you can use Pabbly Connect as your central integration platform. This process allows you to send reminder emails automatically when participant details are added to Google Sheets. By doing this, you enhance attendance and engagement for your webinars.
Initially, you will create a workflow that connects your Google Sheets with Gmail through Pabbly Connect. This integration not only saves time but also ensures that no participant misses important webinar details.
2. Setting Up the Workflow in Pabbly Connect
To start, access your Pabbly Connect dashboard. Click on the “Create Workflow” button to begin. Select the “Create Using Quick Builder” option. This feature allows you to create workflows using AI, which simplifies the process significantly.
  • Click on “New Chat” and select “Yes, Start Fresh”.
  • Enter the prompt: “Create a workflow to send reminder emails to webinar attendees when their details are added in Google Sheets”.
  • Submit the prompt to generate the workflow structure.
Once the structure is generated, approve it and open the workflow in a new tab. This step is crucial as it sets up the integration between Google Sheets and Gmail through Pabbly Connect.
3. Integrating Google Sheets with Pabbly Connect
Next, you need to integrate Google Sheets with Pabbly Connect. This is done by creating a Google Form for webinar registrations. Responses from this form will automatically populate your Google Sheets.
To link your Google Form to Google Sheets, go to the “Responses” tab in your Google Form and click on the “Link to Sheets” button. You can choose to create a new spreadsheet or select an existing one. Once linked, all registration details will flow into your Google Sheets automatically.
  • Select the existing spreadsheet where you want the data to be stored.
  • Press the “Select” button to finalize the integration.
Now, with Google Sheets integrated, you can set up the trigger in Pabbly Connect to respond whenever new data is added.
4. Configuring Gmail Integration with Pabbly Connect
After setting up Google Sheets, the next step is to configure Gmail within Pabbly Connect. Open the Gmail application in your workflow and click on the “Connect” button. You will have the option to create a new connection by signing in with your Google account.
Once connected, fill in the required details such as the sender’s name and email address. Use mapping to dynamically insert the recipient’s email address from the Google Sheets data. This ensures that each reminder email is personalized and relevant to the specific attendee.
  • Add the email subject and the content of the reminder email.
  • Include relevant details like the webinar topic, date, and time.
Finally, click on “Save and Send Test Request” to ensure that the integration works correctly. This will send a test email to confirm that everything is set up properly.
5. Adding a Delay to the Workflow in Pabbly Connect
To ensure that reminder emails are sent a day before the webinar, you need to add a delay step in your Pabbly Connect workflow. Click on the plus button to add a new action and select “Delay by Pabbly Connect”.
Choose the delay option and set it to send emails 24 hours before the scheduled webinar. Input the date and time in the specified format to ensure accuracy. Once you have configured the delay, press the “Save and Send Test Request” button.
  • Set the delay to 20th May 2026 at 10 p.m. for a 24-hour reminder.
  • Confirm that the response is received successfully.
With this step completed, your workflow is now fully functional, allowing you to automate webinar reminder emails efficiently using Pabbly Connect.
By using Pabbly Connect, you can easily automate webinar reminder emails, enhancing attendance and engagement. This tutorial has guided you through the exact steps to set up this integration with Google Sheets and Gmail effectively.
