1. Setting Up Pabi Connect for Integration
To start integrating There with Trigger, the first step is to set up Pabi Connect. This application allows you to create workflows that automate tasks between different platforms.
Log into your Pabi account by visiting pabyt.com. Click on the “Sign In” button located at the top right corner. If you are a new user, you can sign up for free and get 100 tasks monthly. After logging in, navigate to the Pabi apps page and select Pabi Connect to access your dashboard.
2. Creating a New Workflow in Pabi Connect
To create a new workflow, click on the “Create Workflow” button in Pabi Connect. Name your workflow something descriptive, like “Automatically Send Shopify Customers to GoHigh Level”. Choose the appropriate folder for your workflow and click on “Create”.
- Select the trigger application as Shopify.
- Set the trigger event to “New Order”.
- Connect your Shopify account to Pabi Connect.
Once your workflow is created, you will see a prompt to enter your trigger application details. This step is crucial for ensuring that your automation works correctly.
3. Connecting Shopify to Pabi Connect
In this step, you will connect your Shopify account to Pabi Connect. To do this, you need to create a webhook in Shopify. Go to your Shopify admin panel, click on “Settings”, and then select “Notifications”.
Scroll down to find the “Webhooks” section and click on “Create Webhook”. Choose “Order Creation” as the event and set the format to JSON. Paste the webhook URL provided by Pabi Connect and save the changes. This URL will allow Shopify to send order data to Pabi Connect.
4. Testing the Integration with a Dummy Order
After setting up the webhook, it’s time to test the integration. Create a dummy order in your Shopify store. For example, select a product like “Midnight Elegance Black Dress” and proceed to checkout. Fill in the required details such as email, name, address, and payment information.
Once the order is placed, check your workflow in Pabi Connect. You should see a response indicating that the order details have been captured successfully. This confirms that the webhook is functioning correctly.
5. Adding Action Steps to Create Contacts in GoHigh Level
Now that you have tested the integration, the next step is to add an action to create a contact in GoHigh Level. Click on “Add New Action Step” and search for “Lead Connector V2”. Select the action event as “Create Contact”.
Map the fields from the Shopify order to the GoHigh Level contact fields. For example, map the first name, last name, email, and address. This mapping ensures that every time a new order is placed, the corresponding contact is created in your CRM without manual entry.
In conclusion, integrating There with Trigger using Pabi Connect allows for seamless automation of customer data from Shopify to GoHigh Level. By following these steps, you can ensure that your e-commerce processes are efficient and effective.
