1. Access Pabbly Connect for Automation
To start automating WhatsApp messaging, you first need to access Pabbly Connect. Open your browser and navigate to pabby.com/connect. If you’re a new user, click on the “Sign Up for Free” button to create an account and get 100 free tasks every month.
If you already have an account, simply log in. Once logged in, you will see the dashboard where you can access all Pabbly applications. Click on “Access Now” under the Pabbly Connect section to begin setting up your automation.
Creating a workflow is essential for automating your WhatsApp messaging. In Pabbly Connect, you can create a workflow by selecting “Create from Scratch” or using the “Quick Builder” for a faster setup. Here, we will use the Quick Builder.
- Select the trigger app as Facebook Lead Ads.
- Choose the trigger event as “New Lead”.
- For the action app, select Pabbly Chatflow and choose “Send Text Message”.
After configuring these options, click on “Approve and Create” to finalize your workflow. This step is crucial as it sets the foundation for your automation process.
3. Set Up Trigger for New Leads
Now that your workflow is created, you need to set up the trigger. In Pabbly Connect, select your Facebook account and grant the necessary permissions. Then, choose the Facebook page and lead form you wish to connect.
Once you’ve selected the appropriate options, click on “Save and Send Test Request”. This action will allow you to verify that your trigger is functioning correctly. If successful, you should see a confirmation message indicating that the lead details have been captured.
4. Configure WhatsApp Messaging via Pabbly Chatflow
Next, you will configure the WhatsApp messaging feature using Pabbly Connect. For this, you need to get an API token from Pabbly Chatflow. Navigate to the settings in your Pabbly Chatflow account and copy the API token.
- Paste the API token back into your Pabbly Connect workflow.
- Map the WhatsApp mobile number from the lead details.
- Craft your WhatsApp message, using dynamic fields to personalize it.
After configuring the message, click on “Save and Send Test Request” to send a test message. If everything is set up correctly, you will receive the message on your WhatsApp.
5. Test Your Integration
Finally, it’s time to test your integration. Go back to the Facebook Lead Ads testing tool and generate a test lead. Fill in the required details and submit the form. This will trigger the automation you set up in Pabbly Connect.
Check your WhatsApp to confirm that the personalized message has been received. This step ensures that your automation is working as intended, allowing you to engage with leads instantly as they come in.
This tutorial demonstrates how to automate WhatsApp messaging using Pabbly Connect with Facebook Lead Ads. By following these steps, you can engage with new leads instantly, enhancing your marketing efforts.
