To begin using Pabbly Connect, start by visiting the Pabbly website at pabbly.com. Here, you can either sign in if you’re an existing user or sign up for free if you’re new. This platform allows you to automate tasks and integrate various applications seamlessly.
After signing in, you will be directed to the Pabbly apps page. From here, select Pabbly Connect to access the dashboard. This dashboard provides a clear overview of your workflows and folders, enabling you to manage your integrations effectively.
Next, you need to create a new workflow in Pabbly Connect. Click on the ‘Create Workflow’ button and name it “Automatically Send LinkedIn Leads to GoHighLevel CRM”. Select the appropriate folder for this workflow.
- Click on the ‘Create’ button to finalize your workflow setup.
- Ensure that you have selected the correct folder for organization.
Once created, the workflow will prompt you to set up a trigger. In this case, the trigger application will be LinkedIn, and the trigger event will be “Lead Notification”. This setup will ensure that every new lead from LinkedIn automatically initiates the workflow.
3. Connecting LinkedIn to Pabbly Connect
To connect LinkedIn, select it as the trigger application in Pabbly Connect. After that, click on ‘Connect’ and choose the option to create a new connection. Follow the prompts to authorize Pabbly Connect to access your LinkedIn account.
Once connected, you will need to select your sponsored account from the dropdown menu. After making your selection, click on ‘Save and Send Test Request’. This action allows Pabbly Connect to wait for a webhook response, which is necessary to capture the lead details.
4. Testing the Integration with a Lead Submission
Now, it’s time to test the integration. Open your LinkedIn account and submit a lead through the lead gen form. Fill in the necessary fields, including email and phone number, then submit the form. This action will generate a webhook response in Pabbly Connect.
- Make sure to check the webhook response in Pabbly Connect to confirm that the lead details are captured correctly.
- Verify that all lead information, such as email, phone number, and name, are displayed in the response.
Once you see the response indicating successful lead capture, you can proceed to the next step of adding the lead to GoHighLevel CRM.
5. Adding Leads to GoHighLevel CRM
In this final step, you will add the captured lead to GoHighLevel using Pabbly Connect. Click on ‘Add New Action Step’, and in the action application, search for “Lead Connector V2”. Select the action event “Create Contact” and click on ‘Connect’.
Log into your GoHighLevel account and select the appropriate sub-account. Then, map the lead details received from LinkedIn to the corresponding fields in GoHighLevel. This mapping ensures that every new lead is accurately added to your CRM.
After mapping the details, click ‘Save and Send Test Request’. Check your GoHighLevel contacts to confirm that the new lead has been successfully added. This process illustrates how Pabbly Connect effectively integrates LinkedIn leads into your GoHighLevel CRM.
By following this tutorial, you can effectively integrate LinkedIn with GoHighLevel using Pabbly Connect. This automation allows you to capture leads seamlessly and manage them within your CRM, enhancing your business efficiency.
