To start using Pabbly Connect, open a new tab and type in the URL pably.com/connect. This will take you to the Pabbly Connect landing page where you can sign up for free or log in if you are an existing user.
Once logged in, you will see the dashboard that shows your task allocation. If you are a new user, you can create your first automation workflow by clicking on the “Create Workflow” button. Pabbly Connect allows you to integrate multiple applications seamlessly, making it an ideal platform for automating WhatsApp messages for your real estate leads.
In this section, we will create a workflow that connects WhatsApp with your lead generation source. Click on the “Create Workflow” button and name your workflow, such as “Connect 99 Acres with Pabbly Chatflow”. This name helps you identify the workflow later.
  • Enter the workflow name and click “Create”.
  • Select the trigger application (e.g., 99 Acres) and set it to trigger when a new lead is generated.
  • Use the webhook URL provided by Pabbly Connect to capture lead details.
After setting up the trigger, ensure that the webhook URL is copied and integrated with your lead generation source. This will allow Pabbly Connect to receive new lead data automatically. Once this setup is complete, you can move to the next step of sending messages via WhatsApp.
3. Sending WhatsApp Messages through Pabbly Connect
Now that you have set up the trigger, the next step is to send automated WhatsApp messages using Pabbly Connect. Click on “Add New Connection” under Pabbly Chatflow to set up the WhatsApp integration.
You will need to generate an API token from your Pabbly Chatflow account. Go to the settings in Pabbly Chatflow, click on “API & Webhooks”, and generate a new API key. Copy this key and paste it into Pabbly Connect.
  • Navigate to Pabbly Chatflow and generate your API token.
  • Paste the token back in Pabbly Connect to establish the connection.
  • Map the lead’s phone number and name to personalize your message.
Once the API is connected, draft your WhatsApp message using the mapped fields to ensure that the lead receives a personalized message. This step is crucial for enhancing engagement with potential clients.
4. Testing Your Pabbly Connect Workflow
After setting up the message, it’s essential to test the workflow. Click on the “Save & Send Test Request” button to check if everything is functioning correctly. Make sure you have entered a valid phone number to receive the test message.
If the message is sent successfully, you will see a confirmation in your WhatsApp. This indicates that your automation is working as intended. If you encounter any errors, double-check the phone number format and ensure the API token is correctly configured.
Testing is a vital step in any integration process. It ensures that the automation works seamlessly without any manual intervention. Once confirmed, your workflow is ready to automate WhatsApp follow-ups for new leads.
In this tutorial, we explored how to automate WhatsApp messages for real estate leads using Pabbly Connect. By following the steps outlined, you can enhance your lead management and communication efforts effectively.
Utilizing Pabbly Connect not only streamlines your workflow but also ensures timely follow-ups, helping you convert leads into clients effortlessly.
