1. Setting Up Pabbly Connect for Facebook and Telegram Integration
To begin, access Pabbly Connect by visiting pabblval.com/connect. This platform is essential for automating tasks between Facebook and Telegram. If you are a new user, sign up for a free account to get started with 100 tasks every month.
Once logged in, navigate to the dashboard and click on the “Create Workflow” button. This will open the workflow builder where you can set up the integration between Facebook and Telegram.
2. Creating a Facebook Trigger in Pabbly Connect
In your workflow builder, click on the “Add Trigger” button. Search for “Facebook Pages” and select it as the application. Choose the event as “New Post” and click on “Connect” to link your Facebook account with Pabbly Connect.
- Select “Add a New Connection” if you haven’t connected before.
- Make sure your Facebook account is logged in to proceed.
- Choose the specific Facebook page you want to automate.
After setting up the connection, click “Save and Send Test Request” to capture the response from your Facebook page.
3. Setting Up the Telegram Action in Pabbly Connect
Next, add a new action step by clicking on the “Add Action Step” button. Search for “Telegram Bot” and select it. Choose the event “Send Text Message” and click on “Connect” to establish a connection with Pabbly Connect.
If you haven’t connected Telegram before, choose “Add a New Connection”. You will need to obtain an API token from the BotFather on Telegram. To do this, search for “BotFather” in Telegram and create a new bot by following the prompts.
- Start a conversation with BotFather and create a new bot using the /newbot command.
- Copy the API token provided and paste it into Pabbly Connect.
- Remember to add the bot as an admin in the Telegram group where you want to send messages.
Once connected, proceed to enter the chat ID of the group where messages will be sent.
4. Finalizing the Integration Between Facebook and Telegram
Now, map the message content you want to send to Telegram. Use the mapping feature in Pabbly Connect to dynamically insert the Facebook post details. You can include the post message and link.
To get the post link, you may need to add another action step to retrieve the post details from Facebook. Select “Get Page Post Details” as the event and map the post ID from the previous step.
- Ensure the Facebook page ID is the same as the one used previously.
- Click on “Save and Send Test Request” to confirm the details are correct.
- Verify that the message is sent successfully to Telegram.
After confirming the integration, your setup is complete. Now, every time you post on Facebook, the message will automatically be sent to your Telegram group.
5. Testing the Automation Setup with Pabbly Connect
To test your automation, simply create a new post on your selected Facebook page. Within moments, you should see the message appear in your Telegram group, confirming that Pabbly Connect is functioning correctly.
This integration not only saves time but also enhances engagement across platforms. You can further customize your automation for other social media platforms using Pabbly Connect.
With the automation in place, you won’t need to manually share posts anymore. Just focus on creating engaging content for your audience.
This tutorial illustrates how to automatically send Facebook posts to Telegram using Pabbly Connect. By following these steps, you can streamline your social media management and enhance audience engagement effortlessly.
