1. Accessing Pabbly Connect for Telegram Integration
To automate daily messages on Telegram, start by accessing Pabbly Connect. Open a new tab and visit www.pabbly.com/connect. If you’re new, sign up for a free account to access 100 free tasks each month.
Once logged in, you can create your automation setup. This initial access is crucial as it allows you to leverage the features of Pabbly Connect effectively. After signing up, familiarize yourself with the dashboard where your workflows will be managed.
The first step in automating your messages is to set up a trigger using Pabbly Connect. For this purpose, select the “Schedule by Pabbly” trigger. This feature allows you to schedule your messages automatically every day at a specified time.
  • Choose the frequency as daily.
  • Set the time for 10:00 AM.
  • Click on the save button to confirm your settings.
After saving, Pabbly Connect will automatically trigger the workflow at the specified time. This ensures that your messages are sent daily without manual intervention, streamlining your communication process.
3. Sending Messages via Telegram with Pabbly Connect
Once the trigger is set, the next step is to send a message to your Telegram group. In Pabbly Connect, select the action event as “Send a Text Message” using the Telegram Bot. This is where the automation takes shape.
To connect your Telegram bot, you need to create a new bot using the BotFather in Telegram. Search for BotFather in your Telegram app, click on “Start,” and follow the prompts to create a new bot. You will need to provide a name and username for the bot.
  • Copy the API token provided by BotFather.
  • Paste this token in the corresponding field in Pabbly Connect.
  • Select the chat ID where the bot will send messages.
After configuring these settings, you can test the message sending functionality. This integration is crucial as it allows you to automate daily notifications seamlessly through Pabbly Connect.
4. Finalizing the Automation Setup
With the Telegram bot configured, you can now finalize the automation setup in Pabbly Connect. Enter the message you wish to send daily. For example, you can write: “Good morning team! Hope you’re doing well and ready for a productive day.” This personalized message will be sent automatically.
Make sure to review all the details and then click on the “Save and Send Test Request” button. This action will trigger a test message to your Telegram group, confirming that everything is set up correctly.
Upon successful testing, you will see the message appear in your Telegram group. This confirms that Pabbly Connect is functioning as intended, automating your daily communication with ease.
5. Conclusion
Automating daily messages on Telegram using Pabbly Connect is a straightforward process. By following the steps outlined, you can ensure timely communication with your team without manual effort. This setup not only saves time but also minimizes errors in sending messages.
With Pabbly Connect, you can streamline your workflows and enhance productivity in your business. Start using this powerful tool today to automate your communication effectively.
