1. Accessing Pabbly Connect to Send WhatsApp Messages
To start sending bulk WhatsApp messages, access Pabbly Connect by visiting pabbly.com/chartflow in your browser. This platform allows you to automate WhatsApp communications efficiently.
Once on the Pabbly Chartflow homepage, you will see options to either sign in or sign up. If you’re new, click on the “Sign Up Free” button to create your account. Existing users should simply sign in to get started.
2. Creating a WhatsApp Message Template in Pabbly Connect
Before sending messages, you need to create a WhatsApp template. Within Pabbly Connect, navigate to the template section. Here, you can view approved templates, pending ones, and drafts.
  • Click on “Add Template” to create a new one.
  • Choose between “Add Template” or “Generate with AI”.
  • Fill in the template details and submit for approval.
Once your template is approved by Meta, you can use it to send personalized messages. Remember to include variables for personalization, like the customer’s name.
3. Setting Up a WhatsApp Broadcast in Pabbly Connect
Next, to send your messages, navigate to the broadcast section within Pabbly Connect. Here, you can create a new broadcast campaign by clicking on the “Add Broadcast” button.
Fill in the broadcast details, including selecting the broadcast type and naming it. For example, you might name it “New Promo Code”. You will also need to select the contact list to which you want to send messages.
  • Upload your contacts from a CSV file if they are stored in Google Sheets.
  • Choose between a pre-approved template message or a regular message.
  • Add dynamic variables for personalization in your message.
Once you’ve set everything up, you can test your broadcast by sending a message to your own number to ensure everything works as expected.
4. Scheduling Your WhatsApp Broadcast Using Pabbly Connect
After testing your broadcast, you can schedule it using Pabbly Connect. Decide whether you want to send the messages immediately or at a later time.
If you choose to schedule, select the future date and time for your broadcast. Make sure not to select a past date, as this will send messages instantly.
Click on the “Add Broadcast” button to finalize your scheduling. Once sent, you can view stats such as sent, delivered, and read statuses for your messages.
5. Conclusion: Efficiently Sending Bulk WhatsApp Messages with Pabbly Connect
In this tutorial, we explored how to use Pabbly Connect to send bulk WhatsApp messages efficiently. By accessing Pabbly Connect, creating templates, setting up broadcasts, and scheduling messages, you can automate your communication with customers seamlessly.
Utilizing Pabbly Connect not only saves time but also ensures that your messages are personalized and sent without the risk of being flagged as spam. Start using Pabbly Connect today to enhance your customer engagement!
