To begin integrating Thai with Notion, first, access Pabbly Connect by visiting the Pabbly Connect website. If you’re a new user, click on the “Sign Up Free” button to create an account. This allows you to explore the features, including 100 free tasks each month.
If you already have an account, simply click on “Sign In”. After logging in, you will be directed to the workflow page where you can start creating automations. This is where the magic of Pabbly Connect begins, enabling seamless integration between your applications.
Now, let’s set up the trigger for our automation. In the Pabbly Connect dashboard, select the trigger application as “Thai Form”. This action allows Pabbly Connect to listen for new entries submitted through your Thai form.
Next, choose the event as “New Entry” and click the “Connect” button. You will be prompted to create a new connection by allowing access to your Thai Form account. Once connected, select the specific form you want to track, such as the “Lead Generation Form”. Here’s how to do it:
  • Select “Thai Form” as the trigger application.
  • Choose “New Entry” as the event.
  • Connect your Thai Form account.
  • Select the “Lead Generation Form”.
After setting this up, you’ll need to test the connection to ensure everything is working correctly, which is done by submitting a test entry in your Thai form.
3. Testing the Trigger in Pabbly Connect
After submitting a test entry in your Thai form, return to Pabbly Connect to see if the data has been received. You should see a response indicating that your test data has been captured successfully. This step is crucial as it verifies that the integration is functioning properly.
Once you confirm the data is received, you can move on to set up the action application. In this case, we will integrate with Notion. Select Notion as your action application and choose the event “Create Database Item”. Here’s how to do it:
  • Select “Notion” as the action application.
  • Choose “Create Database Item” as the event.
  • Connect your Notion account.
This setup will ensure that every new entry in your Thai form is automatically added to your Notion database, streamlining your data management process.
4. Mapping Data in Pabbly Connect
Now that we have set up the action application, it’s time to map the data from the Thai form to Notion. This is where Pabbly Connect truly shines, allowing you to dynamically insert data without manual entry. You will need to select the Notion database where you want to send the data and map the fields accordingly.
For example, you can map the first name, last name, email, and contact number from the Thai form response to the respective fields in your Notion database. Here’s how to do it:
  • Map the first name field from Thai form to Notion.
  • Map the last name field similarly.
  • Continue mapping email and contact number fields.
After mapping these fields, save your settings and send a test request to ensure everything is working as expected. This step confirms that your integration is ready to go live, automating the lead capture process effectively.
Conclusion: Automating Your Workflow with Pabbly Connect
In this tutorial, we demonstrated how to integrate Thai with Notion using Pabbly Connect. By following the steps outlined, you can automate the process of capturing leads without any manual effort. This integration not only saves time but also enhances data accuracy.
Using Pabbly Connect allows you to streamline your workflow and focus on what matters most—growing your business. Start using Pabbly Connect today to explore more automation opportunities!
