To start integrating Facebook Lead Ads with Salesforce CRM, you need to access Pabbly Connect. Begin by visiting pabbly.com/connect in your web browser. This will take you to the Pabbly Connect homepage where you can either sign in or sign up.
If you are new to Pabbly, click on “Sign Up for Free” to create an account and receive 300 tasks every month. Existing users can simply sign in. Once logged in, navigate to the Pabbly apps window and click on “Access Now” under Pabbly Connect to reach the dashboard.
After accessing Pabbly Connect, the next step is to create a workflow. You will see three options for building your workflow: “Create from Scratch,” “Create Using AI,” or “Create Using Quick Builder.” For this integration, select “Create Using Quick Builder” to set up your workflow quickly.
- Select the prompt to automate when a new lead comes in from Facebook.
- Choose the trigger as “New Lead Instant” from Facebook Lead Ads.
- Select “Create Contact” as the action for Salesforce CRM.
Once you’ve set this up, review your workflow and click on “Approve and Create” to finalize it. This step ensures that every new lead from Facebook will automatically be added to Salesforce CRM as a new contact.
Now that you have created your workflow, it’s time to connect Facebook Lead Ads to Pabbly Connect. Click on “Connect with Facebook Lead Ads” and select your Facebook account. Grant the necessary permissions to allow Pabbly Connect to access your data securely.
Next, choose the Facebook page where your lead ads are running. For this tutorial, select your page named “Prime Properties.” Then, pick the lead generation form you want to connect. This can be done by navigating to your Meta Business Suite, selecting “All Tools,” and then “Instant Forms” to find your desired lead form.
4. Testing the Connection and Data Mapping
After connecting Facebook Lead Ads, it’s crucial to test the connection within Pabbly Connect. Click on “Save and Send Test Request” to ensure that Pabbly is waiting for a webhook response. To generate a test lead, go to the Meta for Developers page and use the Lead Ads Testing Tool to create a lead.
Once you have successfully submitted a test lead, return to Pabbly Connect. You should see a successful response indicating that the lead details have been captured. This confirms that your trigger is working correctly, and now you can proceed to map the data into Salesforce CRM.
- Map the lead’s first name, last name, email, and phone number to the appropriate fields in Salesforce.
- Use the “Text Formatter by Pabbly” to split the full name into first and last names.
- Ensure all required fields in Salesforce are filled correctly before saving.
After mapping the data, click on “Save and Send Request” again to create a new contact in Salesforce. Upon successful creation, refresh your Salesforce account to verify that the new contact appears.
5. Conclusion
In this tutorial, we demonstrated how to integrate Facebook Lead Ads with Salesforce CRM using Pabbly Connect. By setting up a workflow, connecting the necessary applications, and mapping data, you can automate the lead management process efficiently. This integration saves time and ensures that no lead is missed.
Using Pabbly Connect simplifies the process of managing leads, allowing you to focus on growing your business. If you follow the steps outlined in this tutorial, you can easily replicate this automation for your own needs.
