1. Integrating WhatsApp with Pabbly Connect
In this section, we will explore how to integrate WhatsApp using Pabbly Connect. This integration allows you to capture leads automatically and respond to customer queries effectively. To start, access your Pabbly Connect account and navigate to the dashboard.
Once in the dashboard, click on “Create Workflow”. You will be prompted to name your workflow. For instance, you can name it “WhatsApp Integration”. After naming, select WhatsApp as your trigger application. This step is crucial as it sets the foundation for your automation process.
2. Setting Up the WhatsApp Bot
Next, we will set up the WhatsApp bot to engage with users. The bot will initiate responses based on user messages. To do this, use the “Webhook URL” provided by Pabbly Connect. This URL will be used to connect your WhatsApp bot to Pabbly.
  • Access your Pabbly Connect dashboard.
  • Select “Webhook” as the trigger event.
  • Set this URL in your WhatsApp bot settings.
After setting the webhook URL, you can test the integration by sending a message to your WhatsApp number. This step is essential to ensure that your WhatsApp bot is correctly linked with Pabbly Connect.
3. Capturing Leads and Saving to Google Sheets
Now that your WhatsApp bot is set up, we will focus on capturing leads and saving them to Google Sheets using Pabbly Connect. This setup not only captures leads but also stores them for future reference.
To save leads to Google Sheets, follow these steps:
  • Create a new action event in Pabbly Connect.
  • Select Google Sheets as the action application.
  • Choose the action event to “Add Row”.
  • Map the data fields from WhatsApp to Google Sheets.
This mapping ensures that every lead captured from WhatsApp is automatically added to your Google Sheets, making it easy to manage your appointments and customer information.
4. Sending Follow-Up Messages via WhatsApp
Follow-up messages are crucial for customer engagement, and Pabbly Connect makes this process seamless. After a user books an appointment, you can set up a delay to send reminders.
To configure follow-up messages, use the delay feature in Pabbly Connect. This allows you to specify when the follow-up message should be sent. For example, you can set a delay of 1 minute after the appointment is booked.
Once the delay is set, create a message template for the follow-up. This message can be personalized with the user’s name and appointment details, ensuring effective communication. By utilizing Pabbly Connect, you can automate these reminders, keeping your customers informed and engaged.
5. Integrating AI Assistant for Customer Queries
Finally, we will integrate an AI assistant to handle customer queries through WhatsApp. This feature enhances the user experience by providing instant responses to frequently asked questions.
To set up the AI assistant, create a knowledge base containing answers to common queries. Then, link this knowledge base to your WhatsApp bot via Pabbly Connect. This integration allows the AI assistant to fetch relevant information and respond to users automatically.
After configuring the AI assistant, test its functionality by asking common questions. The assistant should provide accurate responses based on the knowledge base. This setup not only improves efficiency but also enhances customer satisfaction by ensuring quick resolutions to their inquiries.
In this tutorial, we explored how to integrate WhatsApp with Google Sheets using Pabbly Connect. By setting up a WhatsApp bot, capturing leads, sending follow-up messages, and integrating an AI assistant, you can automate your customer interactions effectively. This powerful setup enhances your business communication and improves overall efficiency.
