To start automating your Google Blogger posts, first access Pabbly Connect by visiting pabby.com/connect. This is the central platform that facilitates the integration between various applications, including OpenAI and Google Blogger.
Once on the homepage of Pabbly Connect, you will find options to either sign in or sign up for free. If you are a new user, click on “Sign Up Free” to get started with 100 free tasks each month. Existing users can simply sign in to access their dashboard.
After signing in, navigate to the Pabbly Connect dashboard. Here, you will create a new workflow to automate your blogging tasks. Click on “Create from Scratch” or use the AI workflow builder. For this tutorial, we will select the AI workflow builder.
  • Select the option to start a fresh chat.
  • Describe your desired automation, such as generating blog content daily.
  • Choose the trigger for your workflow, which will be a schedule.
Once you have set up your workflow, select the appropriate applications: OpenAI for generating content and Google Blogger for posting. Review the workflow preview and click “Approve and Create” to finalize your setup.
3. Configuring the Trigger in Pabbly Connect
Next, you will configure the trigger for your workflow in Pabbly Connect. This step defines when your automation will run. Choose the frequency of the trigger, such as daily at a specific time, like 10:00 AM.
After setting the frequency, save your configuration. You will receive a confirmation response indicating that your workflow is successfully scheduled. This ensures that your automation will run as planned every day.
4. Generating Blog Title and Content Using OpenAI
With the trigger set, it’s time to generate your blog title and content using OpenAI. In this step, you will connect OpenAI to Pabbly Connect. First, obtain your API key from your OpenAI account.
  • Click on the link provided to access the API keys section.
  • Create a new secret key and copy it into Pabbly Connect.
  • Select the appropriate model, such as GPT-5.
After configuring the model, input the prompt for generating your blog title. Click “Save and Send Test Request” to generate the title. Repeat the process for the blog content, ensuring to map the title dynamically from the previous step.
5. Posting to Google Blogger Through Pabbly Connect
Finally, you will set up the connection to Google Blogger in Pabbly Connect. Click on “Sign in with Google” and select your Google account to grant access to Pabbly Connect.
Once connected, specify your blog ID and map the title and content generated by OpenAI. Choose the status of the post, such as “Live” or “Draft,” and finalize by clicking on “Save and Send Test Request.” You will receive a successful response indicating that your post has been created.
Using Pabbly Connect, you have successfully automated the process of generating and publishing your blog posts on Google Blogger using OpenAI. This integration streamlines your blogging tasks, saving you valuable time.
By following these steps, you can easily manage your blog content without manual intervention. Automate your blogging process today with Pabbly Connect and OpenAI!
