To start integrating Lindin, Pabbly, Pab, Google, and Facebook, first access Pabbly Connect. Visit the official website and sign in or sign up for free to explore the features.
Once signed in, you will see various applications available for integration. Click on the “Access Now” button for Pabbly Connect to reach the dashboard where you can create new workflows.
Creating a workflow in Pabbly Connect is straightforward. Start by selecting “Create from Scratch” to build your automation. This allows you to customize your workflow according to specific needs.
In the workflow builder, you will set up triggers and actions. Here are the steps to follow:
  • Select “Schedule Workflow” to automate daily tasks.
  • Choose the time you want the automation to run.
  • Click on “Save” to confirm your settings.
With these steps, you have successfully set up the workflow schedule in Pabbly Connect. This will ensure your tasks run automatically every day.
3. Setting Up Triggers for Automation
Triggers are essential in Pabbly Connect to initiate the automation process. For this integration, you will set a trigger that activates at a specific time to generate content.
Follow these steps to set up triggers:
  • Choose “Schedule Workflow” and set it to run every day.
  • Select the time for the trigger to activate.
  • Click on “Save” to finalize the trigger settings.
Once the triggers are set, Pabbly Connect will automatically generate content for your social media platforms at the specified time.
4. Connecting Lindin and Facebook via Pabbly Connect
Next, you will connect Lindin and Facebook using Pabbly Connect. This integration allows you to share generated content on both platforms seamlessly.
To connect these applications, follow these steps:
  • Select “Connect with Facebook” and grant necessary permissions.
  • Choose the Facebook page you want to post on.
  • Map the content generated to the post field in Facebook.
By following these steps, you have successfully connected Lindin and Facebook through Pabbly Connect. Now, any content generated will be posted automatically on both platforms.
5. Finalizing Your Automation with Pabbly Connect
To finalize your automation, ensure all steps are correctly set up in Pabbly Connect. This includes confirming triggers, actions, and connections between Lindin and Facebook.
Review your workflow to ensure it meets your requirements. Once confirmed, click on “Save” to activate the automation. You will receive a success message indicating that your automation is ready.
With your automation finalized, Pabbly Connect will handle the posting of content to your Lindin and Facebook accounts daily, saving you time and effort.
This tutorial outlined how to integrate Lindin, Pabbly, Pab, Google, and Facebook using Pabbly Connect. By following these steps, you can automate your social media posting efficiently, enhancing your digital marketing strategy.
