To start automating your LinkedIn posts, you first need to access Pabbly Connect. Open your browser and navigate to Pabbly.com/n. This will take you to the Pabbly Connect homepage.
Once on the homepage, you will see two options: “Sign In” and “Sign Up Free”. If you are a new user, click on “Sign Up Free” to create an account and receive 100 free tasks each month. Existing users should click “Sign In” to access their dashboard.
After logging into Pabbly Connect, you will need to create a new workflow to automate your LinkedIn posts. Click on “Create New Workflow” on your dashboard. You will see options to create from scratch or use an AI workflow builder.
Select the AI workflow builder option. You will be prompted to describe your workflow. For instance, you can type, “I want to schedule this workflow for every day, and Jamini should generate post content and create it as a new post on LinkedIn.” This sets up the automation parameters.
  • Select the trigger as “Scheduled Workflow”.
  • Choose the frequency as “Every Day”.
  • Set the time to 1 PM.
After configuring these settings, click “OK” and then “Save”. You will now have successfully scheduled your workflow to run every day at the specified time.
3. Generating Content for LinkedIn Posts
The next step involves generating content for your LinkedIn posts using Pabbly Connect. You will need to connect to an AI tool, such as Jamini, to create engaging content. Select “Generate Content” as your action step.
In this step, you will be asked to provide an API token from your AI tool. Click on the hyperlink to access your Google AI Studio account and generate a new API key if you do not have one. Once you have your API key, enter it into the designated field in Pabbly Connect.
  • Add a relevant prompt to guide the AI in generating content.
  • Select the model for content generation, such as JNI 2.5 Flash.
  • Click on “Save and Send Request” to retrieve the generated content.
This process will return the content generated by the AI, which you can use for your LinkedIn posts.
4. Posting the Generated Content on LinkedIn
Now that you have generated the content, it’s time to post it on LinkedIn using Pabbly Connect. You will need to create a new connection to LinkedIn and provide your account credentials. Click on “Connect with LinkedIn” to begin this process.
Once connected, you will be prompted to select the author and map the content generated in the previous step. This is where you will specify the visibility of your post, such as setting it to public.
  • Map the data from the previous step to the content field.
  • Select the visibility settings for your post.
  • Click “Save and Send Request” to finalize the post.
Once you have completed these steps, you will have successfully created a new post on your LinkedIn account with the generated content.
5. Conclusion: Automating LinkedIn Posts with Pabbly Connect
In this tutorial, we explored how to automate LinkedIn posts using Pabbly Connect. By following the steps outlined, you can seamlessly integrate Lindin and Google to generate and share content automatically.
This process not only saves time but also ensures consistent engagement on your LinkedIn account. With Pabbly Connect, automating your social media presence has never been easier.
Start using Pabbly Connect today to enhance your automation workflows and boost your online presence!
