To start automating your daily Facebook posts, you need to access Pabbly Connect. If you are a new user, open your browser and visit pabbl.com/connect. Click on the “Sign Up for Free” button in the top right corner to create an account.
Once signed up, you will receive 100 free tasks per month to explore Pabbly Connect. This allows you to post up to 100 daily motivational quotes for free. If you find it useful, consider purchasing a subscription plan for additional features.
2. Setting Up the Workflow in Pabbly Connect
After logging into Pabbly Connect, navigate to the workflow builder. This is where you will set up your automation process. Click on the “Add Trigger” button to begin.
For the trigger application, select “Scheduled by Pabbly” and choose the event as “Schedule Workflow”. Set the frequency to run daily at 10 a.m. and click “Save”. This ensures that your workflow is scheduled to run every day.
3. Integrating Gemini to Generate Quotes
Next, you will integrate Gemini into your workflow using Pabbly Connect. Click on “Add New Action Step” and select Gemini as the action application. Choose the event “Generate and Edit Image” and click on “Connect”.
If you have an existing connection with Gemini, select it; otherwise, click “Add New Connection”. You will need to input your API key from Google AI Studio. To retrieve the API key, go to Google AI Studio, select “Get API Key”, create a new key, and copy it into your workflow.
- Open Google AI Studio and navigate to “Get API Key”.
- Click on “Create API Key” and name your key.
- Select your project and create the key.
Once you have pasted the API key into Pabbly Connect, select the model (e.g., Nano Banana 2) and set the method to “Generate Content”. Input your prompt for the motivational quote and click “Save and Send Test Request” to generate the image.
4. Posting Generated Quotes to Facebook
After generating the motivational image, the next step is to post it on Facebook through Pabbly Connect. Click on “Add New Action Step” and search for Facebook Pages. Select it and choose the event “Create Page Photo Post”.
Click on “Connect” and log into your Facebook account if prompted. After establishing the connection, select the Facebook page where you want the post to appear. Use the URL generated from Gemini as the photo URL. Instead of typing it manually, use the mapping feature in Pabbly Connect to ensure the URL updates dynamically with each new post.
- Select your Facebook page from the dropdown list.
- Map the photo URL generated from the previous step.
- Add a static description for the post.
Once everything is set, click on “Save and Send Test Request”. You should see a confirmation that your quote has been successfully posted on your Facebook page.
5. Conclusion: Automate Your Facebook Posts with Pabbly Connect
By following this tutorial, you can easily automate your daily Facebook posts using Pabbly Connect and Gemini. Every day at 10 a.m., your motivational quotes will be posted automatically without any manual effort. Enjoy the benefits of automation and save time while inspiring others!
Start using Pabbly Connect today to streamline your social media management and explore its other powerful features for seamless integrations.
