1. Access Pabbly Connect to Start the Integration
To begin the process of integrating Google Blogger with LinkedIn, you first need to access Pabbly Connect. If you’re an existing user, simply log in to your account. If you’re new, open a new tab and search for pabbl.com/connect to reach the Pabbly Connect landing page.
On the top right corner, click on the ‘Sign Up for Free’ button. This allows you to explore Pabbly Connect with 100 free tasks each month. Once signed up, you can choose a subscription plan that suits your needs, whether you’re an entrepreneur or part of a growing team.
After accessing Pabbly Connect, navigate to the workflow builder. Here, you will set up the automation to post articles from Google Blogger to LinkedIn. This involves configuring the trigger and action steps necessary for the integration.
Click on the ‘Add Trigger’ button and select Google Blogger as your trigger application. For the event, choose ‘New Post Added’ and click on ‘Connect’. If you haven’t established a connection yet, select ‘Add a New Connection’ and sign in with your Google account to grant permissions.
  • Select your Gmail account to connect with Google Blogger.
  • Choose the blog ID and set the status to ‘Live’.
  • Click ‘Save and Send Test Request’ to capture the response.
Once the response is captured, you will see the details of the latest blog post. This confirms that Pabbly Connect is successfully reading your Google Blogger data.
3. Configure Pabbly Connect to Post on LinkedIn
Next, you’ll set up the action step to post the captured blog content on LinkedIn. Click on ‘Add New Action Step’ and search for LinkedIn as the action application. For the event, select ‘Share a Simple Text’ and proceed to connect.
If you’ve previously connected LinkedIn with Pabbly Connect, select ‘Select Existing Connection’. Otherwise, click on ‘Add a New Connection’ and log in to your LinkedIn account. After logging in, you will be prompted to select the author for the content.
  • Map the content generated by the previous step to the LinkedIn post.
  • Choose the visibility settings as per your preference.
  • Click ‘Save and Send Test Request’ to finalize the post.
After the request, you should receive a confirmation that the post has been successfully created on LinkedIn. This showcases the power of Pabbly Connect in automating your social media updates.
4. Define Trigger Interval for Google Blogger
Since Google Blogger is a polling-based application, you need to set the interval for how often Pabbly Connect checks for new blog posts. Click on the ‘Set Trigger Time’ option and define the interval.
For optimal performance, set the minimum trigger time to 90 minutes. This means every 90 minutes, Pabbly Connect will check for new blog posts on Google Blogger and trigger the action to post on LinkedIn. Save your settings to ensure the workflow operates smoothly.
This configuration enables a seamless flow of content from your Google Blogger to your LinkedIn profile, ensuring your audience is always updated with your latest articles.
Conclusion: Automate Your LinkedIn Posts Using Pabbly Connect
In this tutorial, we demonstrated how to automate the posting of Google Blogger articles to LinkedIn using Pabbly Connect. By following these steps, you can effortlessly share your content across platforms, saving time and increasing your reach.
