To start integrating Pabbly, Pab, and Google, you need to access Pabbly Connect. Open your browser and search for Pabbly.com Connect, which will take you to the homepage of Pabbly Connect.
Here, you can either sign in if you’re an existing user or click on “Sign Up Free” to create a new account. New users can explore the software with 100 free tasks every month, allowing you to familiarize yourself with the platform.
Once logged in, navigate to the dashboard of Pabbly Connect. Here, you will see options to create a new workflow. Click on “Create from Scratch” to start building your integration.
In the workflow builder, select the AI workflow builder option. You will be prompted to describe the automation you want to set up. For instance, you can write a simple prompt explaining that when a new row is added in Google Sheets, you want to generate content and add it back to Google Sheets.
- Select the trigger as “New Updated Spreadsheet Row”.
- Choose the event as “Update Cell Value”.
- Preview your workflow to ensure accuracy.
After confirming the details, click on “Approve and Create” to finalize your workflow setup.
3. Setting Up Trigger and Action Steps in Pabbly Connect
In this section, we will set up the trigger and action steps using Pabbly Connect. The trigger will be set to capture new data added to your Google Sheets. This ensures that every time a new detail is added, the automation will be activated.
Copy the webhook URL provided by Pabbly Connect. In your Google Sheets, navigate to the extensions, select the Pabbly Connect add-on, and choose “Initial Setup”. Here, paste the copied webhook URL.
- Set the trigger column to the final data column where new entries will be captured.
- Submit the configuration to connect your Google Sheets with Pabbly Connect.
Once the connection is established, test it by clicking on the “Send Test” button. This will confirm that the data from Google Sheets is being captured successfully.
4. Generating Product Descriptions Using AI
With the trigger set, we can now generate product descriptions using AI tools integrated through Pabbly Connect. For this, select the AI tool you wish to use, such as Jamini, and create a new connection.
Click on the link to obtain your API key from your AI tool account. Copy the key and paste it into the relevant field in Pabbly Connect. This step is crucial for the AI tool to function correctly within your workflow.
- Map the data fields from your previous steps to ensure the AI generates accurate descriptions.
- Specify the prompt for generating the product description.
After setting up the AI tool, click on “Save and Send Request”. This action will trigger the AI to generate the product description based on the data provided from Google Sheets.
5. Updating Google Sheets with Generated Content
The final step involves updating your Google Sheets with the generated product descriptions using Pabbly Connect. Select the existing connection and choose the Google Sheets where you want the descriptions to be stored.
Specify the range for updating the sheet. For example, if you want to update column H with the generated descriptions, enter the correct range in Pabbly Connect. Once done, click on “Save and Send Request” to complete the integration.
- Confirm that the updates have been successfully made in your Google Sheets.
- Check the specific column to see the newly generated product descriptions.
With this, you have successfully set up a complete automation process that integrates Pabbly, Pab, and Google using Pabbly Connect.
This tutorial demonstrated how to integrate Pabbly, Pab, and Google using Pabbly Connect. By following these steps, you can automate product description generation and streamline your workflow efficiently.
