To start automating course completion certificates, the first step is accessing Pabbly Connect. If you’re new, visit the Pabbly Connect website and create a free account. Upon signing up, you will receive 100 free tasks each month, which is great for testing your workflows.
Once logged in, you will land on the dashboard of Pabbly Connect. From here, you can create and manage all your automation workflows. Click on the “Create Workflow” button to begin setting up your automation.
In this section, we will create a workflow in Pabbly Connect to automate the certificate generation process. Click on “Create Workflow” and select the option to build from scratch. Name your workflow something like “Automatically Generate Certificates” and choose a folder for organization.
- Click the “Create” button to finalize your workflow setup.
- Make sure to set your trigger application as Google Forms.
- Select the event “New Response Received” to initiate the process.
Now that your workflow is created, the next step is to connect your Google Forms account to Pabbly Connect. This will allow you to capture responses automatically.
3. Integrating Google Forms with Pabbly Connect
To connect Google Forms to Pabbly Connect, you will need to copy a webhook URL provided by the platform. After selecting Google Forms as your trigger, click on the “Connect” button to obtain this URL.
Next, navigate to your Google Forms account and open the form that students will fill out to request their certificates. After publishing the form, copy its link and fill out a test response. Go back to Pabbly Connect to ensure the response is captured correctly. Click on “View in Sheets” to see the submitted data.
- Select “Extensions” in Google Sheets, then go to “Add-ons” and install the Pabbly Connect Webhooks add-on.
- Paste the copied webhook URL into the add-on’s setup.
- Ensure the trigger column is set to the correct column where data will be added.
Once this setup is complete, your Google Forms will be integrated with Pabbly Connect, allowing automatic data capture for certificate generation.
4. Generating Certificates Using Google Slides and Pabbly Connect
The next step involves generating certificates using Google Slides through Pabbly Connect. Select Google Slides as your action application and choose “Create Presentation from Template” as the event. Connect your Google Slides account and select the appropriate certificate template.
To personalize the certificates, use curly brackets for dynamic fields such as the student’s name, course name, and completion date. This mapping process is crucial as it allows the certificate to reflect the specific details of each student.
- Map the student’s full name as the file name for the certificate.
- Select the folder in Google Drive where the certificates will be saved.
- Ensure all necessary fields are mapped correctly for accurate certificate generation.
Once everything is set, click “Save and Send Test Request” to generate the certificate. This process showcases how Pabbly Connect facilitates the seamless integration of Google Slides for dynamic certificate creation.
5. Sending Certificates via Gmail with Pabbly Connect
Finally, to send the generated certificates to students, select Gmail as your action application in Pabbly Connect. Choose the “Send Email” event and connect your Gmail account. Here, you will set up the email content, including the recipient’s address, subject, and body.
Make sure to map the student’s email address from the previous responses and personalize the email content. Attach the generated certificate using the PDF link you obtained from Google Drive. This step is crucial as it ensures that each student receives their certificate directly in their inbox.
- Enter a personalized subject line, such as “Congratulations, your certificate is attached!”
- Map the certificate file name to include the student’s name.
- Click “Save and Send Request” to finalize the email setup.
With this setup complete, students will automatically receive their personalized certificates via email, demonstrating the powerful capabilities of Pabbly Connect in automating workflows.
By using Pabbly Connect, you can automate the entire process of generating and sending course completion certificates efficiently. This integration not only saves time but also enhances the student experience through immediate delivery of personalized certificates.
