To begin your automation journey with Pabbly Connect, open your web browser and navigate to pabbly.com/connect. This platform is essential for integrating various applications like OpenAI and Google Sheets.
Once on the Pabbly Connect homepage, you can sign up for a free account. After signing up, you will have access to 100 free tasks every month, allowing you to test the integration capabilities of Pabbly Connect effectively.
2. Setting Up Google Sheets Integration with Pabbly Connect
In this step, you will set up Google Sheets to work with Pabbly Connect. Start by creating a new Google Sheet where you will input your Instagram Reels ideas. This sheet will act as the data source for your automation.
  • Open Google Sheets and create a new spreadsheet.
  • Input your Instagram Reels story in the first column.
  • Save the sheet and keep it open for the next steps.
Once your Google Sheet is ready, go to the Extensions menu, select Add-ons, and then Get Add-ons. Search for “Pabbly Connect Webhooks” and install this add-on to link your Google Sheets with Pabbly Connect.
3. Creating Webhook Integration with Pabbly Connect
After installing the add-on, you will need to create a webhook in Pabbly Connect. This webhook will capture data from your Google Sheet. Go back to Pabbly Connect and create a new workflow.
In the workflow, select Google Sheets as your trigger app and choose “New Spreadsheet Row” as the trigger event. You will be provided with a webhook URL. Copy this URL and return to your Google Sheet to set up the initial configuration.
  • Go to Extensions > Pabbly Connect Webhooks > Initial Setup.
  • Paste the copied webhook URL into the designated field.
  • Set the trigger column to the last column with data.
Once you have completed this setup, click on the Send on Event option to activate the webhook. Now, every time you add a new row to your Google Sheet, Pabbly Connect will automatically send this data to your workflow.
4. Integrating OpenAI for Content Generation
Next, you will integrate OpenAI with Pabbly Connect to generate captions and hashtags for your Instagram Reels. In your Pabbly Connect workflow, add a new action step and select OpenAI as the app.
Choose the “Create Completion” action event. You will need to enter your OpenAI API key, which can be generated from the OpenAI dashboard. Once you have entered your API key, select the model you want to use, such as “GPT-5.5”.
  • Input the prompt for content generation, detailing what you want, such as captions and hashtags.
  • Map the video idea from your Google Sheet to this prompt.
  • Test the action to ensure it generates the content correctly.
After testing, you will receive the generated captions and hashtags from OpenAI, which can now be sent back to your Google Sheet using another action step in Pabbly Connect.
5. Updating Google Sheets with Generated Content
The final step is to update your Google Sheet with the generated captions and hashtags. In your Pabbly Connect workflow, add another action step and select Google Sheets.
Choose the “Update Row” action event. You will need to select the same Google Sheet you used earlier and specify which row to update with the generated content.
  • Map the generated caption and hashtags to the corresponding columns in your Google Sheet.
  • Test this action to confirm data updates correctly.
  • Once confirmed, save your workflow.
After saving, your automation setup is complete. Now, every time you add a new idea to your Google Sheet, Pabbly Connect will automatically generate captions and hashtags using OpenAI and update your sheet accordingly.
In this tutorial, we explored how to automate Instagram Reels creation using Pabbly Connect, OpenAI, and Google Sheets. By following these steps, you can streamline your content creation process and engage your audience effectively.
