To begin automating personalized emails, you first need to access Pabbly Connect. Open your browser and navigate to pabby.com/connect, where you can sign up or log in.
New users can sign up for free, while existing users can simply log in. Once logged in, you will be directed to the Pabbly apps window. Here, click on “Access Now” under Pabbly Connect to proceed to the dashboard.
2. Setting Up Your Workflow in Pabbly Connect
Creating a workflow in Pabbly Connect is essential for this automation. On the dashboard, use the quick builder option to set up your workflow.
In this workflow, you will define a trigger and an action. The trigger will be when a new lead is generated from Google Ads. The action will be sending a personalized email via Gmail. Follow these steps to set it up:
- Select “Google Ads” as the trigger app.
- Choose the event for the trigger.
After setting up the trigger, you will see a successful response indicating that your trigger is ready. This means that every time a new lead comes in through Google Ads, it will initiate the workflow.
3. Integrating Google Ads with Pabbly Connect
Next, you need to integrate Google Ads with Pabbly Connect. Log into your Google Ads account and navigate to your test campaign where you created a lead form.
In the lead delivery section, you will find the option for webhook integration. Paste the webhook URL you copied earlier from Pabbly Connect. Set a key name, like “test test”, and send test data to confirm the integration. This step ensures that your Google Ads and Pabbly Connect are communicating effectively.
- Add the webhook URL in your Google Ads lead form.
- Send test data to verify the connection.
Once you send the test data, check your Pabbly Connect workflow. You should see the dummy details received, confirming that the integration is successful.
4. Using AI for Personalized Email Generation
With the trigger set, the next step is to generate a personalized email using AI through Pabbly Connect. You will need to set up an action step using OpenAI.
To do this, you must obtain an API key from OpenAI. Click the hyperlink provided in Pabbly Connect to access the API keys window. Create a new secret key, name it, and copy it back into Pabbly Connect.
- Obtain the API key from OpenAI.
- Map the lead’s first name in the prompt for personalized content.
After setting up the API key and mapping the required fields, click on “Save and Send Request”. You will receive a successful response with the AI-generated email content.
5. Sending Emails via Gmail Using Pabbly Connect
Finally, you will send the generated email through Gmail using Pabbly Connect. Select Gmail as the action app and sign in with your Google account to establish the connection.
Fill in the necessary fields, such as sender name and email subject. For the recipient’s email address, map the lead’s email received from the trigger step. After ensuring all details are correct, click on “Save and Send Request” to send the email.
- Select Gmail as the action app.
- Map the email content generated by AI.
Upon successful execution, check your Gmail to confirm that the email was sent correctly. This completes the automation process, ensuring that every new lead receives a personalized email without manual effort.
By using Pabbly Connect to automate email follow-ups for Google Ads leads, you can streamline your digital marketing efforts. This integration not only saves time but also ensures a personalized touch for every lead, enhancing your engagement and conversion rates.
