To start integrating Telegram and Discord, you first need to access Pabbly Connect. Open your browser and navigate to pabbly.com/connect to reach the Pabbly Connect workflow page.
Once there, you will see options to sign in or sign up. If you are new, click on the “Sign Up Free” button to create an account. Existing users can simply log in. Pabbly Connect offers a free trial, allowing you to explore its features without any cost.
2. Setting Up Telegram Bot with Pabbly Connect
In this section, we will configure a Telegram bot to initiate the integration. Start by selecting “Telegram Bot” as your trigger application in Pabbly Connect.
  • Choose “Webhook” as the event to watch for updates.
  • You will need a token from Bot Father to connect your bot.
  • Start a chat with Bot Father on Telegram to create a new bot.
  • Provide a name for your bot, ensuring it ends with “bot”.
After creating the bot, copy the token provided by Bot Father and paste it into the connection field in Pabbly Connect. This allows Pabbly Connect to receive messages from your Telegram group.
3. Configuring Discord Integration via Pabbly Connect
Next, we will set up Discord to receive messages from Telegram. In Pabbly Connect, select “Discord” as your action application.
Choose “Send Channel Message” as the action event. You will need to connect your Discord account by clicking the “Connect with Discord” button. Select the server where you want to send messages.
  • Access your Discord channel settings and navigate to the “Integrations” tab.
  • Create a new webhook and copy the webhook URL.
  • Paste the webhook URL into Pabbly Connect and extract the webhook ID and token.
Once you have configured the webhook, you can proceed to map the message field to dynamically send messages from Telegram to Discord.
4. Testing the Integration Between Telegram and Discord
Now that both applications are set up in Pabbly Connect, it’s time to test the integration. Send a message in your Telegram group where the bot is added.
After sending the message, return to Pabbly Connect and click on “Save and Send Test Request”. This will trigger the webhook response.
  • Check the response in Pabbly Connect to see if the message was successfully fetched.
  • If successful, you will see the message displayed in your Discord channel.
  • This confirms that your integration is working correctly.
By following these steps, you have successfully automated the process of forwarding messages from Telegram to Discord using Pabbly Connect.
5. Conclusion
In this tutorial, we demonstrated how to integrate Telegram and Discord seamlessly using Pabbly Connect. By following the steps outlined, you can automate your messaging tasks effectively.
With Pabbly Connect, you can enhance your workflow and ensure timely updates across platforms without manual intervention. Start using Pabbly Connect today to streamline your communication.
