1. Access Pabbly Connect to Start Integration
To integrate Telegram with Discord, you first need to access Pabbly Connect. Open a new tab and type pabyt.com/connect to reach the Pabbly Connect homepage.
Once there, you will see options to either sign in or sign up for free. New users can click on Sign Up Free to create an account, which provides 100 free tasks every month to explore Pabbly Connect. Returning users can simply sign in.
After logging into Pabbly Connect, navigate to the workflow page. This is where you will set up your automation between Telegram and Discord.
To start, click on the Add New Workflow button. You will need to set a trigger, which in this case is a new message in your Telegram channel. Select Telegram as the trigger application.
- Select the trigger event as Webhook to watch for updates.
- Click on the Connect button to set up the connection.
This process establishes the link between Pabbly Connect and your Telegram account, allowing it to monitor messages.
3. Set Up Your Telegram Bot for Integration
To connect Telegram with Pabbly Connect, you need to create a bot. Open your Telegram app and search for BotFather. This tool helps you create and manage your bots.
Start a chat with BotFather and use the command /newbot to create a new bot. You will be prompted to choose a name and username for your bot. After creation, BotFather will provide you with an access token.
- Copy the access token and paste it into the Pabbly Connect connection setup.
- Click Save to establish the connection.
This allows Pabbly Connect to receive messages from your Telegram bot automatically.
4. Test the Telegram Connection with Pabbly Connect
Once the bot is set up, you need to test the connection. Go back to your Telegram group and add the bot as a member, ensuring it has admin permissions.
Send a test message in your Telegram group to trigger the webhook. Pabbly Connect will listen for this message and display the response once it’s received.
- Verify that the message appears in Pabbly Connect and contains the correct details.
- This confirms the successful integration of Telegram with Pabbly Connect.
Now you are ready to set up the action step to send messages to Discord.
5. Send Messages from Telegram to Discord via Pabbly Connect
After successfully receiving the message from Telegram, click on Add New Action Step in Pabbly Connect. Search for and select Discord as the action application.
Select the action event as Send Channel Message. You will then need to connect to your Discord account by providing the webhook URL from your Discord server.
- Go to your Discord channel settings and create a new webhook.
- Copy the webhook URL and paste it into Pabbly Connect.
Finally, map the message content from the Telegram step to the Discord message field. This allows the messages to be sent automatically without manual copying.
This tutorial demonstrated how to seamlessly integrate Telegram with Discord using Pabbly Connect. By following these steps, you can automate message sharing between platforms effortlessly. Start using Pabbly Connect today to enhance your workflow!
