To start using Pabbly Connect, you need to open your browser and navigate to pabbl.com/connect. If you’re a new user, click on the “Sign up for free” option at the top right corner. This will allow you to explore Pabbly Connect with 100 free tasks per month.
Once you’re signed up, you can create your automation workflow. If you’re an existing user, simply log in to access your workflows. Pabbly Connect is essential for automating tasks between Shopify and Airtable, allowing seamless data transfer.
2. Setting Up Shopify Trigger in Pabbly Connect
To initiate the automation, you will need to set up a trigger in Pabbly Connect. Click on the “Add Trigger” button and select “Shopify v2” as your trigger application. Choose the event as “New Order” and click on “Connect”.
- Select Shopify v2 as the trigger application.
- Choose “New Order” as the event.
- Copy the generated webhook URL.
After copying the webhook URL, navigate to your Shopify store. Go to Settings, then Notifications, and select Webhooks. Click on “Create Webhook” to add the copied URL, selecting “Order Creation” as the event and keeping the format as JSON. Save the settings to establish a connection between Shopify and Pabbly Connect.
3. Capturing Webhook Response in Pabbly Connect
Once the webhook is set up, you need to test the connection. To do this, create a test order in your Shopify store. This will trigger the webhook and allow Pabbly Connect to capture the response. Make sure to complete the purchase to generate the data.
- Navigate to your online store.
- Purchase a product to trigger the webhook.
- Wait for Pabbly Connect to capture the order details.
After placing the order, return to Pabbly Connect and check if the response has been captured. You should see customer details and order information displayed on your workflow dashboard.
4. Adding Airtable Action in Pabbly Connect
Now that you have captured the webhook response, it’s time to add an action step to send this data to Airtable. Click on “Add New Action Step” and search for Airtable. Select it and choose the event as “Create Record”.
Connect your Airtable account with Pabbly Connect. If you have an existing connection, select it; otherwise, create a new one. Ensure you are logged into your Airtable account and grant the necessary permissions.
- Select “Create Record” as the action event.
- Map the necessary fields from the Shopify order to Airtable.
- Test the action to ensure data is sent correctly.
After mapping the fields, click on “Save and Send Test Request”. Check your Airtable to confirm that the order details have been successfully added.
5. Conclusion: Automating Shopify Orders with Pabbly Connect
In this tutorial, we demonstrated how to automate the integration of Shopify with Airtable using Pabbly Connect. By setting up triggers and actions, you can streamline your order management process effectively.
By using Pabbly Connect, you ensure that every new order in Shopify is automatically recorded in Airtable, saving you time and reducing manual data entry errors. Start automating today and experience the efficiency of Pabbly Connect!
