To start automating your LinkedIn posts, access Pabbly Connect by visiting pabbly.com/connect. This powerful tool streamlines the integration process, allowing you to connect various applications seamlessly.
Once on the Pabbly Connect homepage, you can take advantage of the free trial. Click on the ‘Sign Up Free’ button to create your account. After registration, log in to your dashboard, where you can begin creating your automation workflow.
In your Pabbly Connect dashboard, click on the ‘Create Workflow’ button. This initiates the process of setting up your automation for posting on LinkedIn.
  • Select ‘Schedule’ as your trigger application.
  • Set the frequency to run the workflow, such as twice a week.
  • Choose specific days like Wednesday and Sunday.
Now, set the time for your posts to go live. For instance, select 2 PM as the posting time. Click ‘Save’ to finalize your scheduled workflow.
3. Integrating OpenAI with Pabbly Connect
The next step involves integrating OpenAI to generate content for your LinkedIn posts. Click on ‘Add Action’ and select OpenAI as your application.
To connect OpenAI, you will need to enter your API key. Navigate to the OpenAI API key page, log in, and create a new secret key. Copy this key and paste it into Pabbly Connect. After saving, ensure you select the appropriate AI model, such as GPT-5, for generating your content.
4. Requesting Approval for Generated Posts
After generating a post, it’s crucial to seek approval before publishing. Click on ‘Add Action’ again and select the ‘Human in Loop’ feature in Pabbly Connect.
  • Set the action type to ‘Request Approval’.
  • Input your email address for receiving approval requests.
  • Craft a message for the approval request, including the generated content.
This allows you to review the post before it goes live, ensuring quality and accuracy are maintained. Save the action and proceed to the next step.
5. Posting to LinkedIn via Pabbly Connect
The final step is to publish the approved content on LinkedIn. Add another action and select LinkedIn as your application. Choose the event “Share Simple Text” for posting.
Log in to your LinkedIn account through Pabbly Connect. For the content field, map the response from OpenAI, ensuring that the generated post is shared. Set visibility preferences and click ‘Save and Send Test Request’ to confirm the integration.
Once successful, your LinkedIn post will be published at the scheduled time, automating your social media presence effectively. With the integration of Pabbly Subscription Billing, you can manage subscriptions and billing for your services seamlessly.
This tutorial demonstrated how to automate LinkedIn posts using Pabbly Connect and OpenAI. By following these steps, you can enhance your social media strategy while maintaining quality control.
