To start automating your LinkedIn posts, you need to access Pabbly Connect. Open your browser and navigate to pabbly.com/connect. If you’re a new user, click on ‘Sign up for free’ to get 300 tasks every month.
If you already have an account, simply sign in. Once logged in, you will see all Pabbly applications. Click on ‘Access Now’ under Pabbly Connect to enter the dashboard.
After accessing Pabbly Connect, the next step is to create a new workflow. You can choose from three options: “Create from scratch,” “Create using AI,” or “Quick Builder.” For this tutorial, select “Create from scratch” to build a workflow step-by-step.
- Select “Schedule Workflow” as the trigger.
- Choose “Gemini” for content generation.
- Select “LinkedIn” to share the generated content.
Once you’ve set these parameters, click on “Approve and Create” to finalize your workflow setup in Pabbly Connect.
3. Setting Up the Trigger for Automation
In this step, you will set up the trigger for your automation using Pabbly Connect. The trigger will determine when your automation runs. Choose the frequency, setting it to run daily at a specified time, like 11:00 AM.
Click on “Save” after selecting the time. This will ensure your automation is scheduled to execute every day at your chosen time, effectively streamlining your LinkedIn posting process.
4. Integrating Gemini for Content Generation
Now it’s time to integrate Gemini as your AI tool using Pabbly Connect. You will need an API key from Google AI Studio. Click the hyperlink to access your Google AI Studio account.
- Select the API key option to generate a new key or copy an existing one.
- Paste the API key into the designated field in Pabbly Connect.
- Input your prompt for content generation, specifying your niche.
Once you have successfully set up the connection, click on “Save and Send this request” to generate content for your LinkedIn posts.
5. Sharing Content on LinkedIn
The final step involves sharing the generated content on LinkedIn through Pabbly Connect. You will need to authenticate your LinkedIn account by entering your credentials. Once connected, you can select the author and input the generated content.
To make the post dynamic, use the mapping feature to insert the generated content automatically. Set the visibility to public or customize it as needed, then click on “Save and Send this request” to publish your post.
By following these steps, you can automate your LinkedIn posts using Pabbly Connect and AI tools like Gemini. This process ensures that your LinkedIn account is updated daily with relevant content, saving you time and effort.
