1. Introduction to Pabbly Connect for LinkedIn Automation
In this tutorial, we will explore how to use Pabbly Connect to automate LinkedIn posts using Google Sheets and OpenAI. This integration allows you to create professional job opening posts effortlessly.
By leveraging the capabilities of Pabbly Connect, you can streamline the process of posting job details on LinkedIn. This automation is particularly useful for businesses looking to maintain a consistent online presence without manual input.
2. Setting Up Pabbly Connect
To begin, you need to access Pabbly Connect. Go to the Pabbly website and sign in or create a new account. Once logged in, you will be directed to the dashboard where you can manage your workflows.
Follow these steps to create a new workflow:
  • Name your workflow, for example, “Automatically Create LinkedIn Job Opening Post Using AI”.
Your workflow is now created successfully in Pabbly Connect. Next, you need to set a trigger application.
3. Connecting Google Sheets as the Trigger Application
In this step, you will configure Google Sheets as your trigger application in Pabbly Connect. The trigger will activate whenever new data is added to your Google Sheet.
To do this, select Google Sheets as your trigger application and choose the event as “New or Updated Spreadsheet Row”. Click on the connect button to establish the connection.
Next, you will receive a webhook URL from Pabbly Connect. This URL acts as a bridge between Google Sheets and your workflow. Follow these steps:
  • Open your Google Sheets and navigate to Extensions > Add-ons > Get Add-ons.
  • Search for “Pabbly Connect Webhooks” and install it.
  • Refresh your Google Sheets and go to Extensions > Pabbly Connect Webhooks > Initial Setup.
Paste the webhook URL and specify the trigger column (the last column that will trigger the workflow). Click on ‘Send Test’ to ensure the connection works.
4. Generating LinkedIn Posts Using OpenAI
After setting up Google Sheets, the next step is to generate a LinkedIn post using OpenAI through Pabbly Connect. Select OpenAI as your action application and choose the action event as “Chat GPT”.
Connect OpenAI by providing your API key. If you don’t have one, create a new secret key in OpenAI and paste it into Pabbly Connect. Once connected, select the model you wish to use.
In the prompt section, enter a detailed request for the LinkedIn post. You can map the data from Google Sheets to the prompt, ensuring it includes job title, company, location, and other relevant details:
  • Create a professional LinkedIn job opening post using details below.
  • Include key skills, qualifications, and a clear call to action.
  • Limit the output to 120-180 words.
After entering your prompt, save and test the request to generate the LinkedIn post content.
5. Posting to LinkedIn Using Pabbly Connect
The final step is to post the generated content to LinkedIn using Pabbly Connect. Add a new action step in your workflow and select LinkedIn as the action application.
Choose the action event as “Share Simple Text”. Connect your LinkedIn account by entering your credentials. Once connected, map the message content from OpenAI to the LinkedIn post.
Set the visibility to public and save the workflow. You can now test the request to post your content. After testing, check your LinkedIn profile to confirm the post appears as intended.
In this tutorial, we demonstrated how to automate LinkedIn posts using Pabbly Connect, Google Sheets, and OpenAI. This automation simplifies the process of creating professional job posts, saving time and effort for businesses.
