1. Access Pabbly Connect to Automate Facebook Stories
To start automating your Facebook stories, access Pabbly Connect by visiting www.pabbly.com/connect. This platform enables you to integrate various applications seamlessly.
If you are a new user, sign up for free to receive 100 tasks every month. This allows you to test the functionalities of Pabbly Connect without any initial investment. Once you are comfortable, consider upgrading to a paid plan for more features.
After logging into Pabbly Connect, navigate to the “Create Workflow” option. Here, you can set up your automation by choosing to create from scratch.
  • Select a name for your workflow, such as “Automatically Create Facebook Stories with AI”.
  • Choose a folder for your workflow and click the “Create” button.
This initial setup lays the foundation for your automation process, which will include a trigger and action steps utilizing Pabbly Connect.
3. Setting Up the Trigger for Automation
The first step in your workflow is to set up a trigger. In this case, you want to create a promotional story every day at a specific time. Use the “Scheduled Workflow” feature in Pabbly Connect to achieve this.
Specify the trigger to run daily at 5:00 PM. Click on the “Save” button to finalize this trigger setup. This ensures that your workflow will automatically start generating stories at the designated time.
4. Adding OpenAI to Generate Facebook Stories
Next, you will add an action step to generate the story image using OpenAI. Select OpenAI as the action application and choose the “Generate Image” event.
  • Provide your OpenAI API key to establish a connection.
  • Enter a detailed prompt that describes the type of image you want, such as a fashion story for your brand.
  • Set parameters like image number, size, and quality.
Once you click the “Generate Image” button, OpenAI will create a unique image based on your specifications, which will be used for your Facebook story.
5. Publishing the Facebook Story Using Pabbly Connect
After generating the image, the next step is to publish it as a Facebook story. Choose “Facebook Pages” as the action application and select the “Upload Story” event.
Map the image URL from the previous step into the appropriate field. After uploading, add a delay of 2 minutes to ensure the image is fully processed before publishing.
  • Select the Facebook page where you want to publish the story.
  • Use the ID from the upload step to publish the story.
Click on the “Save and Send Test Request” button to finalize the publication. Your story will now appear on your Facebook page, showcasing the image generated by OpenAI.
By using Pabbly Connect, you can automate the creation and publishing of Facebook stories effortlessly. This integration with OpenAI allows for unique, engaging content to be shared daily, enhancing your online presence.
