To start automating your WordPress blog posting, access Pabbly Connect by visiting the official website. You can create a free account to explore its functionalities. This platform enables seamless integration between WordPress and Google Blogger.
Once logged in, you will see the dashboard where you can create new workflows. This is where the magic happens, allowing you to automate posting from WordPress to Google Blogger without manual intervention.
In this section, you will create a workflow in Pabbly Connect. Click on the “Create Workflow” button on your dashboard. This initiates the process of setting up your automation.
To set up the workflow, you will need to select the trigger and action applications. Here’s how to do it:
- Choose WordPress as the trigger application.
- Select “New Post Published” as the trigger event.
- Next, choose Google Blogger as the action application.
- Select “Create a Post” as the action event.
Once these selections are made, click on “Approve and Create” to finalize your workflow settings. This step is crucial as it establishes the link between your WordPress and Google Blogger accounts through Pabbly Connect.
3. Setting Up the Connection Between WordPress and Google Blogger
After creating the workflow in Pabbly Connect, you will receive a webhook URL. This URL acts as a bridge between WordPress and Pabbly Connect. Copy this URL as you will need it to connect your WordPress account.
Now, head over to your WordPress dashboard and navigate to the Plugins section. Install the WP Webhooks plugin if you haven’t already. Follow these steps to set it up:
- Go to the WP Webhooks settings.
- Select “Send Data” and choose “Post Created” as the trigger.
- Add the copied webhook URL in the designated field.
Finally, save your settings. This will ensure that every time a new post is published in WordPress, Pabbly Connect will receive the data and trigger the automation to Google Blogger.
4. Testing the Integration with a New Post
Now that you have set up the connection, it’s time to test the integration. Create a new post in your WordPress account with a title and content. Once you publish this post, Pabbly Connect will automatically fetch the data.
Check your Pabbly Connect dashboard to see if the webhook response is received. If successful, you will see the details of the new post, including the title and content. This confirms that the integration is working as intended. You can then proceed to map the data to Google Blogger.
5. Finalizing the Automation to Google Blogger
To finalize the automation, go back to your Pabbly Connect workflow. Here, you will map the fields from the WordPress post to the Google Blogger post. This allows for dynamic data insertion.
Follow these steps to complete the mapping:
- Select the blog ID from your Google Blogger account.
- Map the title and content fields from the WordPress response.
- Set the post status to “Live” and save the configuration.
After saving, your automation is now complete! Every new post created in WordPress will automatically appear on Google Blogger, ensuring your content is always up-to-date across platforms.
By using Pabbly Connect, you can easily automate your WordPress blog posts to Google Blogger. This integration saves time and ensures your content is consistently shared across platforms. Start automating today!
