To automate your Meta Ads leads, you first need to access Pabbly Connect. Start by visiting pabbly.com/connect in your browser. This will take you to the Pabbly Connect homepage.
If you are a new user, click on “Sign up for free” to get 300 tasks every month. Existing users can simply sign in. Once logged in, navigate to the Pabbly Connect dashboard to begin creating your workflow.
In Pabbly Connect, the next step is to create a new workflow. Click on “Create from scratch” to start fresh. You will be prompted to describe your workflow, so enter: “When a new lead comes in from Facebook lead ads, add it to Google Sheets and Google Contacts.”
- Select “New Lead Instant” for Facebook Lead Ads.
- Choose “Add a New Row” for Google Sheets.
- Select “Create Contact” for Google Contacts.
After confirming your selections, approve and create the workflow. This sets the foundation for your automation process.
3. Setting Up the Trigger for Meta Ads
In Pabbly Connect, triggers are essential for automation. Here, select the app event for Facebook Lead Ads and connect to your account. You will need to allow access to Pabbly Connect to secure your data.
Next, select your Facebook page, which in this case is “Digital Dynamics”, and choose the lead generation form from your Meta Business Suite. Ensure you select the specific form you want to capture leads from.
4. Testing the Integration with Google Sheets and Contacts
To complete the setup in Pabbly Connect, you will need to test the integration. Generate a test lead using the Meta Ads testing tool. Fill in the required details such as industry, services, and budget.
- Industry: Real Estate
- Services: SEO
- Budget: 50,000 to 1 lakh
Once you submit the lead, check Pabbly Connect to see if the response is received successfully. This confirms that your trigger is working correctly.
5. Finalizing Automation with Google Contacts
Now that the lead is captured, the next step in Pabbly Connect is to add the details to Google Sheets and create a new contact. For Google Sheets, map the data from the previous step to ensure the details are filled correctly.
For Google Contacts, use the Text Formatter feature in Pabbly to split the full name into first and last names. Map these fields accordingly to create a new contact in Google Contacts.
In this tutorial, we demonstrated how to automate capturing Meta Ads leads into Google Sheets and Google Contacts using Pabbly Connect. By following these steps, you can streamline your lead management process efficiently.
