To begin automating your Facebook product promotions, start by accessing Pabbly Connect. Navigate to the Pabbly Connect landing page by typing pabyt.com/connect in your browser. Here, you will find options to sign in or sign up for free.
If you are a new user, click on the “Sign up for free” button to create an account. Pabbly Connect offers 100 free tasks monthly, allowing you to explore its features. Existing users can simply sign in to their accounts to start creating workflows.
After signing in, the next step is to create a new workflow in Pabbly Connect. Click on the “Create Workflow” option. You can choose to build your workflow from scratch or use the quick builder feature for ease.
  • Select the trigger app, which in this case is Shopify.
  • Choose the event that triggers the workflow, such as adding a new product.
  • Set the action to create a post on Facebook.
Once you have configured these settings, click on “Approve and Create” to finalize your workflow setup. This step connects your Shopify store to Facebook through Pabbly Connect.
3. Setting Up Webhook in Shopify
To enable the integration between Shopify and Facebook via Pabbly Connect, you need to set up a webhook in your Shopify account. Go to the “Settings” section and then select “Notifications”.
  • Scroll down to find the “Webhooks” section.
  • Click on “Create Webhook” and select the event for product creation.
  • Paste the webhook URL provided by Pabbly Connect and save the settings.
This webhook will notify Pabbly Connect whenever a new product is added, allowing for automatic posting on Facebook.
4. Connecting OpenAI for Captions
To enhance your Facebook posts with engaging captions, integrate OpenAI using Pabbly Connect. Select OpenAI as the next app in your workflow and choose the action to generate content.
You will need to log into your OpenAI account and generate an API key. This key is essential for Pabbly Connect to access OpenAI’s capabilities. Once connected, set up your prompt to include dynamic content from Shopify, such as product names and descriptions.
5. Finalizing the Facebook Post
The last step is to connect your Facebook account to Pabbly Connect. Choose the Facebook Pages app and select the action to create a post. Ensure that you are logged into the correct Facebook account.
Map the caption generated by OpenAI and the product image URL from Shopify to the post. Once everything is set, click on “Save and Send Test Request” to test the workflow. If successful, your Facebook page will now automatically post new product launches with engaging captions created by OpenAI.
This tutorial demonstrates how to automate Facebook product promotions using Pabbly Connect and Pabbly Subscription Billing. By following these steps, you can enhance your e-commerce marketing efforts without manual intervention.
