To start integrating Facebook leads with Zoho CRM, you need to access Pabbly Connect. Begin by searching for Pabbly Connect in your browser and navigating to its homepage.
On the homepage, you will find two options: “Sign In” and “Sign Up for Free”. New users should click on “Sign Up for Free” to explore the platform, while existing users can simply sign in.
Once logged into Pabbly Connect, you will be directed to the dashboard. To create a new workflow, click on “Create Workflow”. This action will allow you to set up the automation process.
In this step, you can choose to create the workflow from scratch or use the quick builder. For this integration, select “Create from Scratch” and name your workflow, such as “Facebook Leads to Zoho CRM”.
  • Choose the trigger app as Facebook Leads.
  • Select the trigger event as “New Lead”.
After setting up the trigger, you will receive a preview of your workflow. Review it and click “Approve and Create” to finalize the setup.
3. Connecting Facebook Leads to Zoho CRM
Next, you will connect your Facebook Leads to Zoho CRM using Pabbly Connect. To do this, click on “Connect with Zoho CRM”. This will prompt you to enter your Zoho CRM domain for authentication.
After entering the domain, Pabbly Connect will request access to your Zoho account. Grant the necessary permissions to allow Pabbly Connect to manage your leads effectively.
  • Select the action event as “Create Contact” in Zoho CRM.
  • Map the lead details from Facebook to the corresponding fields in Zoho CRM.
  • Test the connection to ensure successful data transfer.
After mapping the fields, click on “Save and Send Test Request” to ensure that the integration works correctly. You should see a successful response if everything is set up properly.
4. Testing the Integration with a Sample Lead
To ensure that your integration is functioning correctly, you need to test it with a sample lead. Use the Facebook Lead Ads testing tool to submit a dummy lead.
After submitting the test lead, return to Pabbly Connect and check the workflow to see if the lead details have been captured successfully.
If the test is successful, you should see the new lead reflected in your Zoho CRM account. This confirms that the integration between Facebook Leads and Zoho CRM via Pabbly Connect is working flawlessly.
5. Finalizing and Monitoring Your Workflow
Once the integration is confirmed, you can finalize your workflow in Pabbly Connect. Click on the “Save” button to ensure that all changes are stored properly.
Additionally, monitor your workflow regularly to ensure that new leads are being captured and added to Zoho CRM without any issues. You can also set up notifications to alert you of any failures in the automation process.
With this setup, you can efficiently manage your leads from Facebook Ads directly into your Zoho CRM, enhancing your business’s productivity and lead management capabilities.
In this tutorial, we explored how to integrate Facebook leads into Zoho CRM using Pabbly Connect. This integration streamlines the process of managing leads, allowing for efficient follow-up and improved business operations.
