To start integrating Magic Bricks leads into Google Contacts, you first need to access Pabbly Connect. Open your browser and navigate to pabyt.com. Once there, you can sign in or create a new account.
If you are a new user, click on “Sign up for free” to receive 100 free tasks each month. Existing users can simply click on “Sign in” to access their dashboard. After logging in, select the Pabbly Connect application from the list of Pabbly apps to begin the integration process.
After accessing Pabbly Connect, you will see options to create workflows. Click on “Create Workflow” to start. Name this workflow something descriptive, like “Automatically Add Magic Bricks Leads to Google Contacts”.
  • Select the folder for your workflow.
  • Click on “Create” to finalize your workflow.
Your workflow is now created successfully, and you can proceed to set up the trigger application, which in this case will be Magic Bricks.
3. Setting Up the Trigger with Magic Bricks
In this step, you will configure the trigger for your workflow using Pabbly Connect. Choose Magic Bricks as the trigger application and select the trigger event as “New Leads”.
Click on “Connect” to establish the connection. A webhook URL will be generated, which you need to send to your Magic Bricks account manager to enable the integration. Once the webhook is set up, click on “Capture Webhook Response” to test the connection.
4. Adding Action to Create Google Contacts
After setting up the trigger, the next step is to add an action using Pabbly Connect. Search for Google Contacts as your action application and select “Create Contact” as the action event.
  • Click on “Connect” and sign in with your Google account.
  • Grant permission for Pabbly Connect to access your Google Contacts.
Next, you will need to map the fields from the Magic Bricks lead response to the Google Contacts fields. This ensures that each new lead is added correctly without manual entry.
5. Testing the Integration and Finalizing
Once you have mapped all necessary fields, click on “Save” and then “Send Test Request”. Wait for the response to confirm that the integration is working correctly. If successful, you will see the new lead appear in your Google Contacts.
This process demonstrates how Pabbly Connect automates the workflow between Magic Bricks and Google Contacts. Each time a new lead is generated, it will automatically be added to your contacts without any manual effort.
Using Pabbly Connect to integrate Magic Bricks leads into Google Contacts streamlines your workflow and saves time. This automation ensures that you never miss a lead and keeps your contacts updated effortlessly.
