To begin integrating J Style leads into Salesforce CRM, you need to access Pabbly Connect. Start by visiting the Pabbly website at pabbly.com.
Once on the site, sign in to your Pabbly account. If you’re a new user, click on ‘Sign up for free’ to get started with 100 free tasks monthly. If you already have an account, simply click on ‘Sign in’. After logging in, navigate to the Pabbly Connect dashboard to create your workflow.
In Pabbly Connect, click on ‘Create Workflow’ to set up your automation. Name your workflow something descriptive, like “Automatically Add J Style Leads to Salesforce CRM”.
  • Click on the plus icon to create a new folder if needed.
  • Select the folder where you want to save your workflow.
  • Click on ‘Create’ to finalize your workflow setup.
After creating the workflow, you will see a box prompting you to select your trigger application. In this case, select J Style as your trigger application.
3. Setting Up the Trigger for J Style
For this workflow, the trigger will be a new lead captured from J Style. In Pabbly Connect, select J Style and choose the trigger event as “New Lead”. Click on ‘Connect’ to establish a connection.
You will be provided with a webhook URL from Pabbly Connect. This URL acts as a bridge to connect J Style with Pabbly Connect. Since J Style does not allow users to add this URL directly, you need to send it to your account manager at J Style.
  • Wait for the webhook response to confirm the connection.
  • Once you receive the response, it indicates that the connection is working correctly.
After receiving the response, you can proceed to map the data for Salesforce CRM.
4. Setting Up the Action in Salesforce CRM
Now that your trigger is set, it’s time to configure the action application, which will be Salesforce CRM in this case. In Pabbly Connect, select Salesforce as your action application and choose the action event as “Create Contact”.
Click ‘Connect’ to establish the connection with Salesforce. If you already have a connection, select it; otherwise, create a new one. Grant the necessary permissions to connect Salesforce with Pabbly Connect.
  • Map the fields from J Style to Salesforce, such as first name, last name, email, and phone number.
  • Ensure to use mapping instead of manual entry for dynamic updates.
After mapping all required fields, click ‘Save and Send Test Request’ to verify the setup.
5. Verifying the Lead Creation in Salesforce
Once you’ve sent the test request, check your Salesforce account to verify that the new lead has been created successfully. In Pabbly Connect, you should see a positive response indicating that the contact was created.
Open your Salesforce CRM and navigate to the contacts section to view the newly created contact. You should see all the details you mapped from J Style, confirming that the integration is functioning correctly.
  • Check the contact’s details such as name, email, and phone number.
  • Ensure that all mapped fields are populated correctly.
This process illustrates how effectively Pabbly Connect can automate the workflow between J Style and Salesforce CRM, making lead management seamless.
In this tutorial, we explored how to integrate J Style leads into Salesforce CRM using Pabbly Connect. This integration allows for automated lead management, saving time and effort in your business processes. By following the steps outlined, you can streamline your workflow effectively.
