To begin integrating Housing.com leads with Mailchimp, you first need to access Pabbly Connect. Open your browser and type in paby.com to reach the landing page.
Once there, sign into your Pabbly account. Click on the “Sign In” button at the top right corner. If you are new, you can sign up for free and get 100 tasks monthly to test the platform. Existing users can proceed directly to the dashboard.
After signing in, navigate to the Pabbly Connect dashboard. Here, you can manage your workflows. Click on the “Create Workflow” button to start a new integration.
  • Name your workflow: “Automatically Add Housing.com Leads to Mailchimp”.
  • Select the folder for your workflow, such as “All Automations”.
  • Click on “Create” to finalize your new workflow.
This setup allows you to automate the process of adding leads from Housing.com to your Mailchimp account using Pabbly Connect.
3. Setting Up the Trigger with Housing.com
In your newly created workflow, you will set up the trigger application. Select Housing.com as your trigger application and choose the event as “New Leads”.
To connect Housing.com with Pabbly Connect, you will receive a webhook URL. This URL acts as a bridge between the two applications. Since Housing.com does not allow users to add the webhook URL directly, you will need to send it to your account manager for setup.
Once your setup is complete, click on “Capture Webhook Response” in Pabbly Connect. This will change to “Waiting for Webhook Response”. After receiving a response, you will see the details of the lead captured, confirming that the connection is working properly.
4. Adding Action Step to Connect with Mailchimp
After successfully capturing the webhook response, the next step is to add an action application. Click on “Add New Action Step” and search for Mailchimp.
  • Select “Add New Member with Custom Fields” as the action event.
  • Click on “Connect” and choose to create a new connection.
  • Enter the required data center and API token from your Mailchimp account.
This step ensures that every new lead from Housing.com is automatically added as a subscriber in Mailchimp using Pabbly Connect.
With the action step configured, you must enter the required subscriber details. Select your audience list and map the fields such as email address, name, and phone number from the captured lead.
After entering the necessary details, click on “Save and Send Test Request”. This action will test the integration to ensure that the lead is successfully added to your Mailchimp account.
Once the test is successful, you can check your Mailchimp audience to confirm the new subscriber has been added. This automation showcases how Pabbly Connect seamlessly integrates Housing.com leads into Mailchimp, streamlining your workflow.
In this tutorial, we explored how to use Pabbly Connect to automate the process of adding Housing.com leads to Mailchimp. By following these steps, you can enhance your lead management and marketing efforts efficiently.
