1. Accessing Pabbly Connect to Start Automation
To automate adding subscribers to your Kit account, the first step is to access Pabbly Connect. If you’re an existing user, simply open your workflow builder. For new users, visit pabbl.com/connect and sign up for free.
Once signed up, you’ll receive 100 free tasks per month, allowing you to explore Pabbly Connect without any costs. This means you can create up to 100 Kit subscribers using Pabbly Connect for free.
After accessing Pabbly Connect, the next step is to set up your automation trigger. Click on the ‘Add Trigger’ button and select the form builder application, such as Typeform, to initiate this process.
  • Select ‘New Entry’ as the event.
  • Connect to your existing Typeform account, or create a new connection.
  • Ensure your Typeform account is logged in for seamless integration.
Once connected, select the form you want to use for automation. This will allow Pabbly Connect to capture responses automatically.
3. Capturing the Webhook Response
To capture the webhook response, you need to open the form link in a new tab and submit a test entry. This is crucial for verifying that Pabbly Connect is receiving the data correctly.
After submitting the form, return to Pabbly Connect to check if it has captured the response. This confirms that your connection is successful and ready for further actions.
4. Adding the Subscriber to Kit
Now that you’ve captured the webhook response, the next step is to add the subscriber to your Kit account. Click on ‘Add New Action Step’ and search for Kit v4.
  • Select ‘Insert or Update Subscriber by Email’ as the event.
  • Connect to your Kit account, ensuring it’s logged in.
  • Map the subscriber details from the previous step to ensure dynamic data entry.
After mapping the details, click on ‘Save and Send Test Request’ to create the subscriber in your Kit account. This process highlights the efficiency of using Pabbly Connect for automation.
5. Finalizing the Integration with Pabbly Connect
With the subscriber now added to Kit, you can further enhance your workflow by adding the subscriber to a specific sequence or form. Again, select Kit and choose the appropriate event.
Map the subscriber ID and any necessary details to finalize the integration. This step showcases how Pabbly Connect streamlines the process of managing subscribers effectively.
Once completed, your automation is fully functional, allowing you to sit back and relax as Pabbly Connect manages your subscriber additions seamlessly.
In this tutorial, we explored how to automate adding subscribers to your Kit account using Pabbly Connect. This powerful tool simplifies the process, allowing for efficient subscriber management with minimal effort. Start utilizing Pabbly Connect today for your automation needs!
