To begin integrating Brevo, Pabbly, WBook, and Google, you first need to access Pabbly Connect. This powerful platform allows you to create automated workflows between applications seamlessly.
Start by searching for Pabbly.com Connect in your browser. You will be directed to the homepage, where you can either sign in if you’re an existing user or sign up for free if you’re new. New users receive 300 tasks every month to explore the software.
Once you are logged into Pabbly Connect, the next step is to create a new workflow. Click on the ‘Access Now’ button to enter the dashboard and begin building your connection.
To create a workflow, select the option to create from scratch. You can also choose to build using AI or a quick builder. For this tutorial, we will use the quick builder. Here are the steps to follow:
- Select “Create from Scratch”.
- Choose “Google Ads” as the trigger application.
- Select “New Lead Form Entry” as the trigger event.
After selecting the trigger, you will set up the action to create or update a contact in Brevo. This step will ensure that every new lead from Google Ads is automatically added to your Brevo account.
In this section, we will configure the trigger and action using Pabbly Connect. After selecting your trigger, you will see a preview of your workflow. If everything looks correct, approve and create the workflow.
Next, you will need to map the data from Google Ads to Brevo. Here are the steps to map:
- Copy the Webhook URL provided by Pabbly Connect.
- Log into your Google Ads account and set up the webhook with the copied URL.
- Select the fields you want to send, like first name, last name, and email.
After setting this up, test the integration to ensure that the data flows correctly from Google Ads to Brevo through Pabbly Connect.
4. Finalizing the Integration with Brevo and WBook
After successfully mapping the data, you can finalize the integration by connecting Brevo and WBook through Pabbly Connect. This allows for seamless data transfer and management.
To complete the integration, you will need to create a new connection in Brevo. Follow these steps:
- Enter your domain and API key from Brevo.
- Generate the API key in your Brevo account settings.
- Save the connection once the API key is entered.
Now you can test the workflow to ensure that new leads are added to Brevo as expected, completing the integration process.
5. Conclusion: Automating Your Leads with Pabbly Connect
By following these steps, you can effectively automate the process of adding new leads from Google Ads to Brevo using Pabbly Connect. This integration not only saves time but also enhances your marketing efforts.
Utilizing Pabbly Connect for integrating Brevo, WBook, and Google allows for a streamlined workflow that maximizes efficiency. With automation, you can focus more on your business while ensuring that no lead is missed.
In conclusion, integrating Brevo with Google Ads through Pabbly Connect is a straightforward process that brings significant benefits to your marketing strategy.
