1. Accessing Pabbly Connect for Your WhatsApp Automation
To automate your WhatsApp Business, you first need to access Pabbly Connect. Visit pabbly.com/chatflow to get started. This platform provides the tools necessary for integration with WhatsApp and other applications.
Once on the Pabbly Chat Flow homepage, you can log in if you already have an account. If you’re new, you can sign up for a free trial to explore the features. After logging in, you will see a dashboard that displays all the Pabbly applications.
2. Setting Up Your AI Agent in Pabbly Connect
To create an AI agent for your WhatsApp Business, navigate to the Pabbly Chat Flow section. Here, you’ll find the option to create a new AI assistant. Click on the “Add” button to start the setup process.
  • Click on “Add” to create a new assistant.
  • Name your assistant and proceed.
  • Choose the type of instructions for your AI from the dropdown menu.
After naming your assistant, you will be directed to a flow window where you can configure the AI settings. Choose the instruction type that fits your business needs, such as an AI agent. This is where Pabbly Connect facilitates the integration of your WhatsApp Business with the AI capabilities.
In this step, you will configure various settings for your AI assistant. The first setting is the “Temperature,” which determines how creative the AI’s responses will be. A lower temperature means more focused responses, while a higher temperature allows for more creativity.
  • Set the Temperature to 0.4 for focused responses.
  • Select OpenAI as your AI provider and choose the GPT-5.4 model.
  • Input your OpenAI API Key to link it with your assistant.
Once you have configured these settings, Pabbly Connect ensures that your AI assistant is ready to handle customer inquiries effectively. Remember to obtain your API key from your OpenAI account to complete this integration.
4. Finalizing Your AI Assistant in Pabbly Connect
After configuring the basic settings, it’s time to finalize your AI assistant. You will need to set up the “Stop keyword,” which allows the assistant to pause responses when certain keywords are triggered by users.
  • Add keywords like “stop” to halt the AI’s responses.
  • Set up a fallback message for when the AI cannot respond accurately.
  • Provide a knowledge source for the AI to answer customer queries effectively.
By implementing these features, Pabbly Connect enhances the functionality of your AI assistant, making it a reliable resource for your WhatsApp Business communications.
5. Activating Your AI Assistant in Pabbly Connect
Once your AI assistant is configured, the final step is to activate it. Ensure you toggle the activation button to make your assistant live. Click on the “Save” button to store all your settings.
After saving, you can also embed this assistant on your website if needed. With Pabbly Connect, your WhatsApp Business is now automated, allowing for seamless customer interactions.
In this tutorial, we demonstrated how to automate your WhatsApp Business using Pabbly Connect. By following these steps, you can set up an AI assistant that enhances customer engagement and streamlines communication.
