To start automating your Facebook posts, you need to access Pabbly Connect. Open your browser and navigate to pav.com/connect. From here, you have two options: sign in or sign up for a free account.
If you’re a new user, click on the “sign up free” option to receive 100 free tasks every month. Existing users can simply sign in. Once logged in, you will see the Pabbly apps window where you can access Pabbly Connect by clicking on “Access Now.” This takes you to the Pabbly Connect dashboard.
After accessing Pabbly Connect, the next step is to create a workflow. You will see two options: “Create from scratch” and “Create using AI.” For this tutorial, select the AI option for a more guided setup.
- Choose the AI workflow builder.
- Enter a prompt describing your automation needs.
- Select the appropriate triggers and actions for your workflow.
Once you have entered your prompt, Pabbly Connect will analyze it and suggest the necessary triggers and actions. You can then approve and create the workflow, receiving a link to access it anytime.
3. Setting Triggers and Actions in Pabbly Connect
In this step, you will set up the trigger and action for your workflow. The trigger defines when the automation will start, and actions define what happens after the trigger. For this automation, select a schedule trigger to run your workflow on specific days.
- Choose the days of the week for automation.
- Select a specific time for the automation to run.
- Save your settings to confirm the trigger.
Now that your trigger is set, you can move on to defining the actions. For this setup, you will use Gemini to generate content and images for your Facebook posts. This integration is seamless through Pabbly Connect, allowing you to automate content creation effortlessly.
4. Integrating Gemini with Pabbly Connect
With your workflow in place, the next step is to connect Gemini to Pabbly Connect. You will need to enter an API key from your Google AI Studio account. Click on the link provided in the interface to access your Google account.
- Copy the existing API key or create a new one.
- Paste the API key into the required field in Pabbly Connect.
- Save the connection to finalize the integration.
After successfully connecting Gemini, you will enter the prompt for content generation. This step allows you to instruct the AI on what type of content to create for your Facebook posts, ensuring relevance and engagement.
5. Posting Generated Content on Facebook
Once the content and images are generated, you will set up the final action to post on Facebook. In Pabbly Connect, select your Facebook account and grant the necessary permissions for posting.
- Choose the Facebook page where you want to post.
- Map the image and content generated from Gemini to the respective fields.
- Click on “Save and send test request” to verify the post.
After a successful test, your automation is ready. This means that every time the scheduled trigger activates, Pabbly Connect will automatically generate content and share it on your Facebook page, streamlining your social media management.
In this tutorial, we explored how to automate Facebook posting using Pabbly Connect and Gemini. By following these steps, you can save time and enhance your social media strategy with automated content creation and posting.
