1. Create a WhatsApp AI Agent Using Pabbly Connect
Creating a WhatsApp AI agent is straightforward with Pabbly Connect. First, access your Pabbly Connect account and navigate to the AI agent creation page. This is where you will set up the automation for your WhatsApp conversations.
Once on the page, select the AI instruction type as “AI agent”. This will automatically populate the necessary fields. You can customize these instructions further based on your specific needs.
2. Integrate OpenAI API with Pabbly Connect
To enhance your WhatsApp AI agent, you need to integrate the OpenAI API through Pabbly Connect. Start by selecting OpenAI as your AI to use. Make sure to choose the appropriate model, such as GPT-5 mini, to suit your requirements.
- Select “OpenAI” from the AI options.
- Input your API key, which you can create by following the provided link.
- Click on “Connect” to ensure the API is linked successfully.
Ensure that you have the paid version of OpenAI to avoid any limitations. This integration allows your AI agent to respond effectively to user queries on WhatsApp.
3. Configure AI Agent Settings in Pabbly Connect
Next, customize your AI agent settings within Pabbly Connect. You can add header and footer messages to enhance user interaction. Toggle the buttons to enable these features and input your desired messages.
Additionally, set a stop keyword that users can send to halt the automated responses. This is crucial for instances where human intervention is necessary. You can also specify a retry attempt range, allowing the AI to attempt to respond multiple times if it fails initially.
4. Upload Your Knowledge Base for Effective Responses
For your WhatsApp AI agent to provide accurate answers, you need to upload a comprehensive knowledge base via Pabbly Connect. This knowledge base should include details about your services, contact information, and other relevant data.
- Choose the option to upload a file from your local storage.
- Ensure the file format is either TXT or PDF for compatibility.
- Click “Insert” after selecting the uploaded file to finalize the process.
This detailed knowledge base will empower your AI agent to provide meaningful responses based on user inquiries on WhatsApp.
5. Finalize and Activate Your AI Agent in Pabbly Connect
After configuring all settings, it’s time to finalize your AI agent in Pabbly Connect. Ensure that the toggle to keep the AI agent active is turned on. Then, click the save button to store your settings.
You can also embed the AI assistant into your website for broader access. Assign the AI assistant to specific chats, groups, or all contacts to streamline your communication process. This feature is essential for automating responses across various user interactions.
In this tutorial, we explored how to create a WhatsApp AI agent using Pabbly Connect. By integrating OpenAI and uploading a knowledge base, you can automate your WhatsApp conversations effectively. This AI assistant will enhance your customer interaction and service efficiency.
