1. Accessing Pabbly Connect for WhatsApp AI Integration
To start using Pabbly Connect for integrating WhatsApp AI, first, you need to visit the Pabbly website. Type in ‘pabbly.com/chartflow’ in your browser. This will take you to the Pabbly Chatflow homepage.
If you’re a new user, click on ‘Sign Up for Free’ to create an account. Existing users can simply log in. Once logged in, navigate to the Pabbly Chatflow dashboard where you can set up your WhatsApp AI chatbot.
2. Creating Your WhatsApp AI Chatbot with Pabbly Connect
Once you are on the Pabbly Chatflow dashboard, you can start creating your WhatsApp AI chatbot. Click on the ‘Add’ button to create a new assistant. Give your assistant a name and proceed to configure it.
  • Select the instruction type from the drop-down menu.
  • Set the AI model to OpenAI and specify the temperature for responses.
  • Add your OpenAI API key to connect the assistant.
After setting these parameters, you can customize additional settings such as header messages and keywords that will trigger the assistant to stop responding, ensuring a smooth user experience.
3. Configuring Your AI Assistant in Pabbly Connect
In this section, you will configure the AI assistant settings in Pabbly Connect. This includes setting a header message, footer message, and specifying keywords that will deactivate the assistant when typed by users.
To set the header message, toggle the button and enter your desired text. For the footer message, you can also add a support contact. Additionally, define the retry attempts for the assistant and the fallback message for incorrect API responses.
  • Enter a fallback message to guide users when the assistant fails to respond.
  • Upload a knowledge source file in plain text format for accurate responses.
  • Customize the assistant interface by adding your brand name and initial messages.
These configurations ensure that your WhatsApp AI chatbot is well-prepared to handle customer queries effectively.
4. Activating Your WhatsApp AI Chatbot with Pabbly Connect
After configuring your assistant, the next step is to activate it. In Pabbly Connect, enable the assistant by toggling the corresponding button. Click on the ‘Save’ button to ensure all your settings are stored properly.
Once activated, you can assign your assistant to WhatsApp chats. Navigate to the inbox settings and enable the AI auto-reply feature. Select the contacts and the assistant you wish to assign. Save these settings to automate responses for those contacts.
For single chat assignments, go to the inbox section, select the specific chat, and enable the assistant for that chat. This flexibility allows you to manage responses efficiently across multiple chats.
5. Conclusion: Automating Your WhatsApp Business with Pabbly Connect
In conclusion, using Pabbly Connect to integrate WhatsApp AI can significantly enhance your business communication. By following the steps outlined in this tutorial, you can create an efficient chatbot that responds to customer queries instantly.
With the ability to customize and automate responses, Pabbly Connect empowers businesses to manage customer interactions seamlessly. Start leveraging this powerful tool today to boost your WhatsApp business efficiency.
