To start automating your sales process, access Pabbly Connect by visiting their website. Once you’re there, sign up or log in to your account. This is essential for creating your workflow.
After logging in, you will be directed to the dashboard. Here, click on the “Create Workflow” button to initiate the process of setting up your automation. This step is crucial as it lays the foundation for connecting your applications.
2. Connecting Facebook Lead Ads to Pabbly Connect
In this section, we will link Facebook Lead Ads to Pabbly Connect. Start by selecting Facebook Lead Ads as your trigger application. This is where your automation begins.
  • Choose “New Lead” as the trigger event.
  • Click on the “Connect” button to establish a connection.
  • Log in to your Facebook account if prompted.
  • Select the Facebook page associated with your lead ads.
After completing these steps, you will be ready to receive lead data directly into Pabbly Connect. This integration ensures that every new lead is captured automatically, saving you time and effort.
3. Generating AI Responses with OpenAI
Next, we will use OpenAI to generate personalized responses based on the leads captured by Pabbly Connect. Select OpenAI as your action application.
  • Choose “Generate Response” as the app event.
  • Connect your OpenAI account by entering the API key.
  • Map the lead information from Facebook to the OpenAI prompt.
This integration allows Pabbly Connect to send lead details to OpenAI, which will generate a customized message. This message can then be sent to the lead automatically, enhancing your customer engagement.
4. Sending Messages via Pabbly Chatflow
Now, let’s connect Pabbly Chatflow to send the generated message to WhatsApp. Start by selecting Pabbly Chatflow as your next action application.
  • Choose “Send Text Message” as the app event.
  • Connect your Pabbly Chatflow account using the token provided in your settings.
  • Map the WhatsApp number and the AI-generated message.
By completing these steps, Pabbly Connect will facilitate the automatic sending of personalized WhatsApp messages to your leads. This feature is key in maintaining timely communication with potential customers.
5. Creating Contacts in Zoho CRM
Finally, we will integrate Zoho CRM to create a new contact with the lead information captured by Pabbly Connect. Select Zoho CRM as your action application.
Choose the “Create Contact” option and connect your Zoho account by entering the domain and granting permissions. After that, map the lead details such as name, email, and phone number to the respective fields in Zoho CRM.
This final step ensures that every new lead not only receives a personalized message but is also logged into your CRM for future follow-ups. Pabbly Connect automates this entire process seamlessly, allowing you to focus on other aspects of your business.
In this tutorial, we explored how to automate your sales process using Pabbly Connect by integrating Facebook Lead Ads, OpenAI, Pabbly Chatflow, and Zoho CRM. This automation saves time and enhances customer engagement effectively.
