To start integrating WhatsApp AI with your business, access Pabbly Connect. This platform simplifies the automation process by connecting various applications seamlessly. Begin by navigating to the Pabbly Connect homepage.
If you are a new user, click on the “Sign Up Free” button to create an account. Existing users can simply log in. Once logged in, you can explore the features of Pabbly Connect that will allow you to automate your interactions effectively.
2. Creating Your AI Assistant Using Pabbly Connect
After logging into Pabbly Connect, navigate to the AI assistant page. Here, you can set up your WhatsApp AI assistant. This assistant will respond to customer queries automatically, enhancing your business communication.
  • Select the instruction type as “AI Agent”.
  • Adjust the temperature setting to control the creativity of responses.
  • Provide your OpenAI API key to connect the assistant with Pabbly Connect.
Ensure you save your settings after making these configurations. This setup will allow your AI assistant to fetch data from the provided knowledge base, ensuring accurate responses to customer inquiries.
3. Setting Up Your Knowledge Base in Pabbly Connect
The next step involves creating a knowledge base for your AI assistant. This knowledge base acts as the brain of your assistant, containing all necessary information about your business.
Upload your knowledge base document in either TXT or PDF format through Pabbly Connect. Make sure to include key points about your services, which will help the AI assistant provide accurate responses.
After uploading, you can preview how the knowledge base will be displayed to users. This is crucial for ensuring your customers receive relevant information promptly.
4. Configuring AI Settings in Pabbly Connect
In this section, configure the settings for your AI assistant within Pabbly Connect. This includes setting up the header and footer messages, as well as specifying stop keywords that can deactivate the assistant when needed.
Additionally, you can define retry attempts in case the AI fails to respond. This ensures that your customers always receive a reply, enhancing their experience.
  • Set the initial message that users will see when they interact with the assistant.
  • Customize the look and feel of your assistant by selecting themes and colors.
  • Enable the “Powered by Pabbly” label for branding purposes.
Once all configurations are complete, save your AI assistant settings to ensure they are active.
5. Enabling Your AI Assistant for Customer Interaction
Finally, enable your AI assistant to start interacting with customers through Pabbly Connect. Navigate to the settings and enable AI auto replies for your contact list.
You can also enable the assistant for specific chats. This allows for a tailored experience depending on the customer’s needs. Simply select the chat and choose the AI assistant you created.
After enabling, your assistant will automatically respond to customer queries, significantly reducing manual interaction. This automation is a game-changer for businesses looking to streamline their customer service operations.
Using Pabbly Connect, you can effortlessly automate your business communication with WhatsApp AI. This integration allows for efficient customer interactions, enhancing your service quality and saving time.
