1. Accessing Pabbly Connect for WhatsApp Automation
To automate your business WhatsApp messages, start by accessing Pabbly Connect. Open your browser and go to chat.pabbly.com. This tool is essential for creating your WhatsApp chatbot.
Once you have registered your account, ensure that you add your WhatsApp number to your Pabbly Chat Flow account. This integration is crucial for setting up your automated responses.
2. Creating Your Chatbot Flow in Pabbly Connect
After logging into Pabbly Connect, navigate to the left sidebar and select “Flows”. This action takes you to the flow builder page where you can create your chatbot.
  • Select the “Add Flow” button to start a new flow.
  • Drag and drop message blocks to design your welcome message.
  • Add buttons to your message for user interaction.
Make sure to save your flow by clicking the “Save” button after completing your design. This ensures that your chatbot is ready for use.
3. Setting Up Triggers in Pabbly Connect
To initiate your WhatsApp automation, you need to set up a trigger in Pabbly Connect. The trigger is the event that starts the chatbot. For instance, when a user sends a “Hello” message, it activates the chatbot.
In the flow builder, select the trigger event and configure it by entering the keyword that will activate the chatbot. This step is crucial as it defines how users will interact with your chatbot.
  • Define the keyword for activation.
  • Test the trigger to ensure it works as expected.
This setup allows your chatbot to respond automatically when the specified keyword is detected, enhancing user interaction.
4. Designing Chatbot Responses with Pabbly Connect
Next, design the responses your chatbot will provide using Pabbly Connect. This involves creating various message blocks that the chatbot will send based on user selections.
For example, you can offer buttons for users to explore services, request a consultation, or access service brochures. Each button should link to a specific message block that provides detailed information.
  • Create a welcome message with buttons for user options.
  • Add response blocks for each button click.
  • Ensure each block is linked to the correct follow-up action.
By structuring your responses effectively, you enhance the user experience and ensure that your chatbot provides relevant information quickly.
5. Utilizing AI Assistant in Pabbly Connect
To further enhance your chatbot’s capabilities, integrate an AI assistant using Pabbly Connect. The AI assistant can answer user queries automatically based on a knowledge base.
Set up the AI assistant by navigating to the actions section in Pabbly Connect and selecting the AI assistant option. You will provide it with a knowledge base that contains answers to common queries.
  • Input the knowledge base details into the AI assistant.
  • Customize the welcome message for the AI assistant.
This feature allows your chatbot to handle more complex inquiries, providing a seamless experience for your users.
By following this tutorial, you can effectively automate your business WhatsApp messages using Pabbly Connect. This integration allows you to enhance customer interaction through automated responses and AI assistance, ensuring a streamlined communication process.
